March 26, 20197 yr comment_184073 On 3/19/2019 at 12:04 AM, Woodbutcherbynight said: Like most tools of this nature you only have so many parts. The chuck can be removed by removing the screw in the bottom. To access open chuck up all the way. Should be a #3 or #2 Philips screwdriver bit. This would allow you to work only on the chuck itself without risk of chemicals getting inside the drill. Diagram that shows parts in question. https://www.ereplacementparts.com/porter-cable-pcl120ddc2-12v-lithium-cordless-drill-parts-c-129_2127_282785.html New chuck if desired is $16.10 Hope this helps. I was just going to post that. I have a couple of local repair/parts shops that are typically cheaper than ereplacementparts.com, so it'd pay to look there first. IIRC the screws holding the chuck on most drills are at the bottom of the chuck mechanism and are LEFT HAND THREADS. Report
March 26, 20197 yr comment_184078 8 minutes ago, kmealy said: IIRC the screws holding the chuck on most drills are at the bottom of the chuck mechanism and are LEFT HAND THREADS. Yes I should have mentioned this. Good catch. Report
