March 14, 20197 yr comment_182470 As a pharmacist I see loads of stock plastic bottles which drugs come to the store in thrown out daily. I use one for Watco so do not have to open the can as much. I think they are HDPE. If you could find one to fit that top you have would be prefect. Report
March 16, 20197 yr Author comment_182803 6 hours ago, Stick486 said: How about something like these??? I started looking at other bottles for their code. I found a bottle under the sink that had additive for the dishwasher to make for less spots. It had the HDPE code on the bottom so I put what was left in the dishwasher, cleaned the container and put acetone in it. I left it in a tin can for a test to see how well it holds up. The tin can will contain the leak if necessary. Sometimes I use a 1/4" or a 1/2" brush to put finish on small items and will just wet the brush with the proper solvent and wipe it on a rag rather than putting some in a small container to wash out the brush. Sometimes I just want a little on a rag to wipe off a little adhesive residue. Anyway this is what I use. If the HDPE container doesn't work out I will go to the glass hot sauce bottle. Edited March 16, 20197 yr by HandyDan Report
March 17, 20197 yr comment_182811 1 hour ago, HandyDan said: Anyway this is what I use. I would add to your having labeled the bottle to write a DATE on it. Everything in my shop gets a date before being put away. Takes some time to start now with everything you have but once you get that done when you buy it date it and put away. Only reason I do this is far too often I would look and find a can of this or that and wonder when did I get this, is it too old? Now, oh I bought this in 2008, it is paint, probably bad.... Of course I also have to wonder why did I keep it this long.... Report
March 17, 20197 yr comment_182853 12 hours ago, HandyDan said: If the HDPE container doesn't work out I will go to the glass hot sauce bottle. glass in the shop is to be feared.... the butterfly effect can really get out of control... Report
March 30, 20197 yr Author comment_184927 Update. The acetone has been in the HDPE bottle for two weeks and so far shows no signs that the plastic is weakening. Report
