December 15, 20187 yr Popular Post I don't know why I never thought of this, it's so common too, just another way to turn an existing tool into another. @Gene Howe. Does Shopsmith till make the sander for the lathe, I could not find it. OR
December 15, 20187 yr It's a good idea. You can also turn your shopsmith into a mini thickness sander by positioning the table under that drum. Steve
December 15, 20187 yr Author @Gene Howe. Never mind, found it! http://www.shopsmith.com/ownersite/catalog/sn_inflatablesander.htm
December 15, 20187 yr Author Just now, Steve Krumanaker said: It's a good idea. You can also turn your shopsmith into a mini thickness sander by positioning the table under that drum. Steve It's genius, with the Shopsmith, and the incredible versatility with their variable speed, the sander would work great I would imagine.
December 15, 20187 yr You could save the $80 and make your own holder for the sanding sleeves and then just mount it between centers.
December 15, 20187 yr Just re-read my comment above the video I posted. Lest someone gets the wrong idea, Shopsmith does not make that sander. That one was made by Paul Miller in his Tucson shop. I've used it. It's a neat machine. I'm sure the idea could be adapted to a lathe with no problem. Edited December 15, 20187 yr by Gene Howe
December 15, 20187 yr Author Thanks Gene. It's on my list! I got rid of my Performax a few years ago, took up too much space, I used it rarely, so it wasn't worth it to keep around for stubbed toes. But there are occasions one could come in handy, and to have one you could hang on the wall, would be beneficial.
