November 14, 20188 yr Popular Post comment_166489 I have requests for showing how I thread the bolt and nuts in the TP Dispenser Post. It is the same way that you thread metal rods,and tap metal plate for bolts. I use Slipit for a lubrication so as to not tear out the threads. Here I show an oak dowel and maple nuts. I use Slipit on drawers rails, drawer slides, and any wood that needs to slide. https://www.slipit.com/all-products/...ding-compound/ Report
November 15, 20188 yr comment_166506 41 minutes ago, DAB said: i'd do 5 sided nuts, just to be different. ovals... Report
November 15, 20188 yr comment_166510 1 hour ago, DAB said: i'd do 5 sided nuts, just to be different. I'd do the old style 4-sided square head machinery nuts to make it easy. Report
November 15, 20188 yr comment_166511 Thanks Herb for showing the process...Like your wooden hinges, I enjoy the uniqueness & extra detail in your projects. Report
November 15, 20188 yr Popular Post comment_166528 Stick you may be a sadist Herb that is a great tutorial . Thanks Report
November 15, 20188 yr comment_166532 43 minutes ago, Gerald said: Stick you may be a sadist Herb that is a great tutorial . Thanks but I don't get much company... Report
November 15, 20188 yr Popular Post comment_166535 1 hour ago, Gerald said: Stick you may be a sadist Or a "WRECKT-ALL" surgeon Report
November 15, 20188 yr comment_166562 Thanks for showing how to do this. Now where do I go to buy the tools to make my own? Preston Report
November 15, 20188 yr comment_166577 Dadio, what is the main ingredient in slipit? It says a sealing compound but does it double as the glue? How does it strengthen the threads from fracture? Report
November 15, 20188 yr Author comment_166592 3 hours ago, steamshovel said: Thanks for showing how to do this. Now where do I go to buy the tools to make my own? Preston I bought the one I have from Lee Valley,which can be bought on Amazon or Grizzly: https://www.amazon.com/Wood-Threading-Tools/s?page=1&rh=i%3Aaps%2Ck%3AWood Threading Tools Lee Valley sells the new Beal system that uses a router now: The Beall Tool Company Also the one like mine can be bought at Garret Wade: https://www.garrettwade.com/wood-threader-tap-and-die-set-gp.html Herb Edited November 15, 20188 yr by Dadio Report
November 15, 20188 yr comment_166596 Thanks Herb, I was wondering if the TP holders shaft came apart like a regular bolt or not, or if you just slipped the roll over the shaft. Nice pictorial tutorial as to how you went about it. @Stick486 The sight of your various forms of TP brought tears to my eyes. OUCH! It brought back memories of when I had to have surgery after having my first colonoscopy. Some how when they Roto-Rooted me they tore the rectal lining, and I had to have surgery to correct it. I couldn't sit for at least 6 weeks, they ended up removing about 40% of my Wrecked Rectum. Needless to say I refuse to go through that again. That isn't happening, No Way!!!I don't care what they say. Edited November 15, 20188 yr by Larry Buskirk Report
November 15, 20188 yr comment_166605 Now I don't know what size to buy. What size do you have shown? I may go with 3/4 to 1 ". Preston Report
November 15, 20188 yr comment_166606 19 hours ago, Stick486 said: ovals... hex nuts become oval nuts after sufficient pressure from slip joint pliers is applied..... Report
November 15, 20188 yr comment_166607 Ovals would be real easy to turn by hand like a wing nut... Report
