July 22, 20188 yr comment_154832 A friend of mine runs a feed store. He recently bought a livestock trailer to deliver goods in. I helped him put in Lexan windows and now he's looking for something to put on the aluminum floor to level it out. It has 1" high sort of triangular tubing every 12" or so, front to back. His original though was to put in some 1" (probably 5/4) rough-sawn poplar. But it's air dried and cracked and warped. I'm wondering if 5/4 PT decking would work? Any other suggestions? Does not want to add a lot of unnecessary weight. Foam insulation under 1/2" CDX? 2x2 grid under ply??? Report
July 22, 20188 yr comment_154834 I would choose plywood for the uniformity. Any place around to get some one inch plywood? Report
July 22, 20188 yr comment_154835 plywood fillers and cover w/ rubber reinforced stable mats.. the chemicals from the PT may leach into the feed... Report
July 22, 20188 yr comment_154836 Just now, HandyDan said: I would choose plywood for the uniformity. Any place around to get some one inch plywood? two layers of ½''... Report
July 22, 20188 yr comment_154841 I'd go with the double layer 1/2" ply and preferably stainless steel screws but at minimum weather resistant coated screws. You only need enough screws to hold the ply secure...not like a sub-floor. Check with a trailer dealer/repair shop for the screws. Report
July 22, 20188 yr comment_154847 8 minutes ago, Grandpadave52 said: I'd go with the double layer 1/2" ply and preferably stainless steel screws but at minimum weather resistant coated screws. You only need enough screws to hold the ply secure...not like a sub-floor. Check with a trailer dealer/repair shop for the screws. winged (reamer) TEKs are the ticket... SS not required w/ these... Report
July 23, 20188 yr comment_154852 I think the idea of a layer of foam insulation covered with a layer of ply would work well. I would glue the foam to the ribs and attach the ply with the screws recommended by Stick. Report
July 23, 20188 yr comment_154855 1 hour ago, Stick486 said: winged (reamer) TEKs are the ticket... SS not required w/ these... run them in at slow to medium speed.. if the aluminum is really ''gummy'' predrill a small pilot hole... Report
July 23, 20188 yr comment_154857 18 minutes ago, Stick486 said: why the insulation??? Cheaper than another layer of ply? 3/4 rigid would work. I'd still go with the two layers of 1/2" ply screwed to the ribs. Maybe some adhesive in the middle. Report
July 23, 20188 yr Author comment_154859 41 minutes ago, Stick486 said: why the insulation??? Weight and just to fill the space. Report
July 23, 20188 yr comment_154863 20 minutes ago, kmealy said: Weight and just to fill the space. common foam board will compress and granulate..... VOE 1'' extruded polystyrene insulation sheets topped w/ CDX or OSB... Report
July 24, 20188 yr comment_154944 Let not forget what he is transporting. Pigs, Horses, Cattle, Sheep all have hooves and the plywood wold be very torn up an smelly after a short while. PT would not be good for the animals. The animals will containment the wood. I would go with a topper of 1/8" to 1/4" sheet brushed aluminum. Make sure you have drain holes that do not allow any puddles. Report
July 24, 20188 yr comment_154948 Ya know, I've never seen a feed store with anything but wood floors. Many with osb and/or plywood flooring. Report
July 24, 20188 yr comment_154955 A feed store does not have the same issues because livestock are not permitted in the feed store. Now I see he bought a livestock trailer to put his goods from the feed store in. Sorry I miss read the first statement. So wood is acceptable. After a through cleaning and bleaching of the trailer. Edited July 24, 20188 yr by Michael Thuman Report
July 24, 20188 yr comment_154964 We always used good old 2X6 planks spaced 1/8" apart for drainage,(Lots of rain here), bolted down every 2' with 2-5/16" galvanized carriage bolts. Herb Report
July 25, 20188 yr comment_154995 What was the triangular tubing for? What sort of floor does it have now? I would not be concerned with using 5/4 PT lumber if it is cost effective for you. Most of the stuff being delivered will be in bags or boxes. It sounds like the trailer has a roof and windows, so it won't get wet. For those odd items not packaged like salt blocks you could always lay them on a piece of plastic or cardboard (or not). Report
July 26, 20188 yr Author comment_155038 It's got a textured aluminum floor. Not sure why the ridges unless for stiffeners. The tops are rounded, I suppose so as not to damage hooves. It did have some vent openings all around, about 4" high, that we filled with Lexan to keep water out. Report
July 26, 20188 yr comment_155071 @kmealy - here is some info that might be helpful: http://theplywood.com/weight Comparing the weight difference between plywood and "high moisture" yellow pine, the plywood wins by a lot. Since this sounds like it will be mostly for safety to mitigate trip hazard from the ridges you might be ok with a layer of 3/4" or a double layer of 1/2". Report
July 26, 20188 yr comment_155075 On 7/25/2018 at 5:27 AM, Cal said: using 5/4 PT lumber w/ all the worl that I did in the grain mills... PT was not allowed because of the possibility of chemicals leaching into the feed... don't believe for a heartbeat that floor won't get wet... rain... doors open.. wet feed stack... wet hand truck... wet pallet... wet bodies.. the 1st horse/critter that gets sick and the ambulance chasers will come a head hunting... seen that happen several times.... Edited July 26, 20188 yr by Stick486 Report
