Popular Post Fred Wilson Posted July 13, 2018 Popular Post Report Posted July 13, 2018 I think your choice of blade for a particular job really is a personal choice with prior knowledge of your cutting habits. There are times where I will change sizes or type of blade during the cutting of a piece ! ie: long straight or slight curved lines vs tight inside cuts. Blade choice also depends on the speed of your saw, the thickness of the wood, and the hardness of the wood. OK - I don't think there is a hard and fast rule. Your style of cutting will choose your blade size and type. Cal, DuckSoup, Harry Brink and 3 others 5 1 Quote
Al B Posted July 13, 2018 Report Posted July 13, 2018 For cutting band saw boxes I use a 3/16"- 10 TPI or 4 TPI for cutting tight curves The 4 TPI does cut faster, but the 10 TPI produces a smoother cut, requiring less sanding. For the straight cuts, a 1/2" 10 TPI works well. Fred Wilson and Cal 2 Quote
DuckSoup Posted July 14, 2018 Report Posted July 14, 2018 Before I start cutting on a pattern line I like to make a couple of cuts in a scrap area of the wood. This helps to get a feel of the pressure I'll use & if I've picked the right blade for the finish cut I'm looking for. Fred Wilson, Cal, Al B and 1 other 4 Quote
Fred Wilson Posted July 17, 2018 Author Report Posted July 17, 2018 Great replies, guys - thanks Quote
hawkeye10 Posted August 31, 2018 Report Posted August 31, 2018 There is no telling how much money I have spent on blades trying to find blades that I like for what I do. I use the Pegas blades and the reason I like them so much is I can feed my work straight into my work. Pegas Modified Geometry (MGT) Don Quote
Fred Wilson Posted August 31, 2018 Author Report Posted August 31, 2018 Don, know what you mean. Most "modified Geometry" style blades are machined instead of stamped. Both sides of the blade are identical meaning they won't pull one direction or the other. Good choice. DuckSoup 1 Quote
