November 29, 20179 yr comment_132718 I have limited experience with Acrylics and I need some advice on gluing. In the past I have used CA to glue acrylics to wood, however I have always used a center post to assure that it would stay together. Can I successfully glue a flat acrylic material to a flat wood piece and then turn it without worrying about it coming apart. It will be a small piece, such as a Christmas ornament. Thanks Report
November 29, 20179 yr comment_132719 I've never tried this but I wonder if the joint adhesive they use for Corian countertops would work. Here's a site that may help- http://www.thistothat.com/ or this- http://www.e-tplastics.com/blog/how-to-attach-plexiglass-acrylic-to-wood/ and I found this- Edited November 29, 20179 yr by lew Report
November 29, 20179 yr comment_132736 I watch N Z Woodturning on youtube a lot. Nick does it all the time but I am not sure what glue he uses. I know it's not CA glue, it looks more like titebond. Report
November 29, 20179 yr Author comment_132738 I received a free sample of Rapid fuse and have really liked the results. However, even tho I have sealed it good when I finished, the glue is getting more like jello in the container. I am thinking of giving it a try on some scrap. Will let you know how it works out Report
November 29, 20179 yr Author comment_132739 Thanks Rusty, that is a very good reference. I may set up a test piece for goop too Report
November 29, 20179 yr comment_132748 I glued my shoe with Goop Glue. Held together for a very long time. It must be good stuff and I believe it glues anything to anything. Report
November 29, 20179 yr comment_132752 3 hours ago, Ron Altier said: Rapid fuse and have really liked the results I agree with that. I'm using mine more and more. Report
