Is there a way
Is there a way to grip finished pieces in the chuck with minimal damage? I want to center and redrill an eight inch hole in a small piece.
It is bamboo and I'm thinking that it will splinter out. Never drilled that stuff.
Ron, there are several ways to do what you want I think. If I understand what you're doing a jamb chuck is probably your answer. Basically you turn a recess in a piece of scrap that your piece will fit into snugly. Its pretty easy to do and if the opening is a little big paper towels make good shims.
Steve
Not sure of the orientation of the piece you want to grip. There is a turner I follow that has some really innovative chucks-
His site is here-
http://www.davidreedsmith.com/default.htm
Here's a link to more chuck ideas
https://www.woodturningonline.com/articles.php?catid=9
Edited by lew
