February 18, 20179 yr comment_98709 14 hours ago, HandyDan said: Oily wood would be the ones to stay away from. so what do you do for glue up and bleeding if you opt to use them??? Report
February 18, 20179 yr Author comment_98735 I am not a fan of the oily woods if I am mixing and matching for effect because of the problems they can cause. Gluing oily wood takes another step of wiping the surface to be glued with some acetone or lacquer thinner to remove the oil. Glue as soon as possible after the solvent evaporates. Sealing the lighter colored wood with sanding sealer can help greatly with the bleeding while sanding. Blowing off with compressed air is another help. GLUEING TROUBLESOME WOODS.pdf Gluing Oily Exotic Woods.pdf Edited February 18, 20179 yr by HandyDan Report
February 18, 20179 yr comment_98742 53 minutes ago, HandyDan said: I am not a fan of the oily woods if I am mixing and matching for effect because of the problems they can cause. Gluing oily wood takes another step of wiping the surface to be glued with some acetone or lacquer thinner to remove the oil. Glue as soon as possible after the solvent evaporates. Sealing the lighter colored wood with sanding sealer can help greatly with the bleeding while sanding. Blowing off with compressed air is another help. GLUEING TROUBLESOME WOODS.pdf Gluing Oily Exotic Woods.pdf thank you sir... Report
