December 6, 20169 yr comment_86639 I gotta say mounted in my angle grinder it's ferocious. Smooth (no grabbing) aggressive and it is Frightening. My grinder isn't paddle switch so if it gets out of my hands it's still going. Well I'll get used to it. I got used to standing up once too. Edited November 24, 20179 yr by Ron Dudelston tags added Report
December 6, 20169 yr comment_86653 47 minutes ago, Dadio said: Please be careful. Herb PLEASE!!! Report
December 6, 20169 yr comment_86666 Quote I got one also and have used it in my angle grinder and it is a wild thing to say the least. Mine keeps on going when it is dropped. I would like a switch that stops NOW when there is no finger pressure. I talked to a guy who carves for a living and he showed me his left hand where the cutting edge got all 4 finger joints. It cut down deep and they worried about losing all 4 fingers. He healed and seven months later he got back to using his left hand again. He said take it slow and hold on and pay attention if I am going to keep using it. I may just have to find another way. Cliff Please, Please be careful Preston Edited December 6, 20169 yr by steamshovel Report
December 6, 20169 yr comment_86684 2 hours ago, Dadio said: Please be careful. Herb Yes, please do - my uncle got his hand cut up by one pretty bad one time- of course it could have been the fact that the other hand/arm was in a cast or the chair seat he was shaping was clamped to a metal stool, or he did not have the guard on the angle grinder. OR, it was a combination of ALL 3 Report
December 7, 20169 yr comment_86698 Gotta steal @Stick486 line here...SUB IT OUT! Better than changing your name from Cliff to "Stubby" Report
December 7, 20169 yr comment_86747 Okay, that is one tool I never had the urge to buy. Stay safe. Report
December 12, 20169 yr comment_87441 I think of it this way... Would I ever get my hand that close to a chain saw...? And the chainsaw is travelling a much slower rate of speed... imagine your chain saw revving it up to 30,000 RPM plus...? The slide switch on my Makita has two functions...if I push it on from the front of the switch it locks on...if I push it from the rear of the switch it becomes momentary...maybe yours does the same thing and you might not have noticed...? "Stay safe, my friend" Report
December 17, 20169 yr Author comment_88072 Well this'll terrify all ya all about as much as it terrified me. I got it to use on the wood lathe. HUH?? yup. I got these 18" winged bowls I'm doing and I had a wonderment if whether I'd get a better finish by bringing the thing up to the work like a turning tool So I tried it. Hand held. No tool rest. Oh my goodness, it was frightening. I think I'm done with that as a concept. But still if I can build a mechanism to operate like the saddle of a machine lathe ~ ~ ~ ~ ~ ~ Sometimes I wonder if I spend too much time designing and building gizmos trying to avoid developing certain skills. Well, I have fun doing it so, there's that. I still have the reciprocating machine I built to tooth hand saw blanks because I was too impatient to learn the skill. I made it from scrap & junk I just had laying around. That articulated hollowing tool I made was the result of me feeling inadequate to control the tools inside a larger hollow form. Thing is, they all work. Report
December 17, 20169 yr comment_88077 8 minutes ago, Cliff said: Sometimes I wonder if I spend too much time designing and building gizmos trying to avoid developing certain skills. Well, I have fun doing it so, there's that. Know what you mean! Report
December 17, 20169 yr comment_88194 The important thing is.... do you still have all your fingers? John Report
December 17, 20169 yr comment_88199 @Cliff one time I wanted to grind the head of a 3/4" bolt round so I rigged up my small right angle grinder with a clamp block to mount in my 4 way vise on the drill press and used it like a cross feed on a metal lathe with the drill press. Worked like a charm. I wonder if you could make something like that for your wood lathe like the cross feed with the grinder and the Sir Lancelot ? Herb Report
March 19, 20206 yr comment_222056 I use one all the time. Just remember to lift to clear the wood when moving left. Report
April 11, 20206 yr comment_224847 https://www.youtube.com/watch?v=A7xWHEWov8M&has_verified=1 take a look, a breakdown of what one of these can do. If you must use one of these consider a very low powered electric (think HF's cheapest) or an air powered one with the air turned way down. Report
April 11, 20206 yr comment_224854 1 hour ago, Wichman3 said: https://www.youtube.com/watch?v=A7xWHEWov8M&has_verified=1 Yeah that is scary. And I would consider Stumpy a safety conscience oriented guy. Can happen anywhere anytime. Report
