Workbench completion
Gerald
I really thought I had finished this post and discovered today that was not the case . So here goes. Now the lumber was finally here and cutting parts to size and glue up for thicker parts begins.
1617372601_P3120829(Medium).JPG.0723476777cf53ab3498de843acf8d1b.JPGP3120831.JPG.fa3cd49435ddf08c136987a06f1cb5e3.JPG
These wider pieces were real fun doing the glue up on. Kinda like holding a snake who wants to run. The next photo is the legs. Note I used a waxed spacer to keep the slots open and spaced properly for end cross support.
428866078_P3120833(Medium).JPG.3af4f1ddba8a132b2678ede2f8c666d3.JPG1684071424_P3180842(Medium).JPG.578b1b7ee52fcb3294ed38b71345b364.JPG
Now the fun begins with the heavy lifting. Three pieces of MDF half sheets 24 X 72 glued up for the top. And then this is what the wide pieces look like after glue up is cured.
P3180843.JPG.edd97423c726538bb3e4cc9de53bc834.JPGP3180844.JPG.97a70b2d13fd4448dfebc617a3113a87.JPG
Time to edge band the top and a look at the legs with stretcher ready for assembly.
1947513634_P4050850(Medium).JPG.ec0fe29873f4ffd5071394832ff3780e.JPGP4050851.JPG.a7150081e4cf75b716307fd40f53edd0.JPG
Top is now banded and work begins on adding the vices and some heavy trim to hold the vices.
P4050853.JPG.d8b7fc28b406a1ecf49de1e5d3eeb7db.JPG1029287856_P4260991(Medium).JPG.fa6f07f59d3fd17723255eadd8c20df3.JPG
Now to assemble the legs and put the base together.
590175636_P4260992(Medium).JPG.f422a326ed632fdc7d25eb0edb06c9ef.JPG482876444_P5290993(Medium).JPG.941fb1f7d9b4e3cb88cd2831633aad0a.JPG
This is a look at the bed bolts holding the base together. The top has a layer of 1/4 masonite to allow changing is damaged. This is secured with brass screws. This top is so heavy there are no fasteners holding it down . It is simply sitting on top of the frame.
1090723468_P5290994(Medium).JPG.d753c0a6e194c4e4fb6f425dd23cd5a6.JPGP6081038.JPG.72d94840da6218720d334253e090e60a.JPG
The drawers units were built later with the top two drawers being added after the others were done. The dog holes were drilled using a block of scrape oak to hold the drill straight. Then they were countersunk to male insertion of dogs easier. This last pic is the back where you can see the addition of two drawers clearly. I did not take pictures of the mounting of the vices and building the front faces, a "fun" job. The drawers now have Kaizan foam lining . Planes drawer is the last photo.1858886218_Planedrawer.JPG.5fe4983bf867423bb3b921ef792d21eb.JPG
IMG_5079.JPG.ad278c021fa8cab612efac40cf9e8eba.JPGIMG_5085.JPG.e368db1c0f54163afe66d79ef764c7d0.JPG
Edited by Gerald
6 Comments
Cal
Posted
Super project Gerald, thanks for the pics :)
  • Like 3
Woodman
Posted
The “Like” button does not convey my appreciation!
My favorite picture, the frame assembly :wub:
  • Like 1
Gene Howe
Posted
That's one good looking and, healthy bench!
  • Like 2
Posted
Thanks for the blog on this Gerald, beautifully done sir!
  • Like 2
Add a comment...
  Only 75 emoji are allowed.
