October 16, 201610 yr Popular Post comment_79305 I recently acquired a slightly used Craftsman BAS350 14" band saw. It is the same saw as the Rikon 10-321 band saw. It is equipped with a one horse power motor and a very nicely machined cast iron table with a rip capacity opening of 8.5". I got a 5/8" 3TPI blade and ran some firewood pieces through it to make turning blanks and was very pleased with the performance. It has a 2" dust port below the blade and a 4" port at the bottom of the lower wheel. I connected a dust collector to the 4" port with great results and see no need to hook up the two inch port. With the 4" port hooked up air was being sucked into the 2" port effectively sucking any dust the 2" port might have yielded. I really liked the idea of blowing the dust out into the back yard. No muss no fuss. The red knob on top of the saw is the blade adjustment knob. It is easily removed which is a nice feature. Once the tension is released the knob can be removed and laid in plain sight on the table as a reminder that the blade needs tensioned before using. It has roller blade guides which are bearings mounted to adjustable pins. One of the bearings was making noise so I oiled it. I got the number off of it to see about getting some spares and found they are inline skate wheel bearings which makes them readily available. In fact, I had bought a set of cheap skates to use the wheels to make a lathe steady and had five extra wheels I could get the bearings out of. I did and sure enough they were the same. All in all, I am happy with the saw. Edited November 24, 20178 yr by Ron Dudelston tags added Report
October 16, 201610 yr comment_79357 Nice review Dan. Thanks for taking time to do so...You may have to alter your dust collection discharge method in a month or two or put on your insulated overalls! Report
October 16, 201610 yr Author comment_79363 I am trying to get all I want cut now before it gets cold. Cut 24 more string top blanks today. 75 degrees out there today. Love it. I Still have a band saw in the basement too. Report
October 16, 201610 yr comment_79366 4 minutes ago, HandyDan said: I am trying to get all I want cut now before it gets cold. Cut 24 more string top blanks today. 75 degrees out there today. Love it. I Still have a band saw in the basement too. Yeah, but running the exhaust piping for that all the way out to the garage then out the door to the yard seems like a lot of extra work not to mention the pipe... Deals like you got on that Craftsman never happen over here. That saw looks like it still smells new. Report
October 16, 201610 yr comment_79375 Definitely a good saw for the price. If you find you need a fence, i recommend the Rikon fence. It fits this saw perfectly, and is priced lower than the Craftsman version. I use my shop vac connected to the 2" port. It keeps most of the dust from flying around but it's not totally effective.I tried taping off the lower 4" connector, but it made little difference. I'm beginning to hear a little noise when cutting with it. Guessing it might be one of the guide bearings, probably the ones behind the blade. I've had good luck using a 3/16" blade for tight curves, though the smallest blade recommended by Craftsman is 1/4". Report
October 16, 201610 yr comment_79383 up size the exhaust size and the DC will work a lot better.... use snap-lock in 6 or 8''... Report
October 17, 201610 yr Author comment_79465 6 hours ago, It Was Al B said: Definitely a good saw for the price. If you find you need a fence, i recommend the Rikon fence. It fits this saw perfectly, and is priced lower than the Craftsman version. I use my shop vac connected to the 2" port. It keeps most of the dust from flying around but it's not totally effective.I tried taping off the lower 4" connector, but it made little difference. I'm beginning to hear a little noise when cutting with it. Guessing it might be one of the guide bearings, probably the ones behind the blade. I've had good luck using a 3/16" blade for tight curves, though the smallest blade recommended by Craftsman is 1/4". Made my own fence for it Al. See these two threads. Report
November 29, 20169 yr comment_85811 I have the Ricon version of this saw. At the urging of the rep that sold it I purchased the Carter blade back support. This lets me backoff all guides except the below table back bearing. With a [ sharp ] 3/16 4 tpi blade I find that this arrangement will do most anything I ask of it. Did I mention that I really like the Carter blade support-------works for me. Report
January 11, 20179 yr comment_92226 On 11/29/2016 at 0:23 PM, Marv Rall said: I have the Ricon version of this saw. At the urging of the rep that sold it I purchased the Carter blade back support. This lets me backoff all guides except the below table back bearing. With a [ sharp ] 3/16 4 tpi blade I find that this arrangement will do most anything I ask of it. Did I mention that I really like the Carter blade support-------works for me. I am looking at adding this support to my Jet 14 inch band saw, I ahve heard very good things about it. Looking at adding another band saw to the shop, Thanks to the OP for the Review! Report
August 25, 20251 yr comment_360611 Hi all , I am trying to find out how much the Sherwood EABS350 bandsaw was when new cheers. Report
August 25, 20251 yr comment_360615 Welcome to the forum! Would that saw (Sherwood) be the same as Dan's Craftsman? Edited August 25, 20251 yr by Fred W. Hargis Jr Report
