August 24, 201610 yr comment_69425 This Spalted Magnolia hollow form is turned from wood from the old Federal Courthouse in Jackson,MS. The tree was cut down by a subcontractor who was not supposed to do that. I asked my DIL what her favorite color was and got pink as the answer. So I did a light red, then use acrylic paint on the rim for a "crowning " touch.Then we went to visit and I left this in a bag at home. Oh the inside is painted with Black Gesso since spalting was bad enough I could not get a good finish inside so with the black no reflection and difficult to see bottom. Report
August 24, 201610 yr comment_69439 Your daughter is probably very sad no to get that beautiful vase. I pull the same forgetting trick more often than I would like to admit. The mind is always looking ahead instead of the task at hand. Dan Report
August 24, 201610 yr comment_69454 I can't think of anything that can continue to keep history, in our minds, than creating something from a piece of wood with this much background. Report
August 24, 201610 yr comment_69457 VERY NICE. Since it is very old, I was wondering if the color we see has oxidized and is much darker than original? Its probably more than 100 years. Report
August 25, 201610 yr Author comment_69503 The color is Chestnut Stain (red diluted about 4 ml in 20 ml alcohol). The rim I did someting unusual on the turning by spliting the bead or in other words I dis a modified vee. Then I painted the vee with gold acrylic paint. So yes I do use paint sometimes. Thanks for the comments Edited August 25, 201610 yr by Gerald left off something Report
