Showing results for tags 'variable speed'.
Now THIS is cool! Shopsmith 10ER Multi tool WWW.EBAY.COM Find many great new & used options and get the best deals for Shopsmith 10ER...
- 2 replies
- 10er
- variable speed
(and 1 more)
Variable Speed Control plugged into a Harbor Freight Wood Lathe
AndrewB posted a topic in Wood Turners
So this morning I went hunting around for my variable speed control. Which I had previously used for my blower fan that connected to my twier and into my coal fire forge. Worked quite nicely for that and moved a ton of air. Either way I had repurposed it. I wanted to test something out to see if I could get a slower speed than 600 RPM on the Harbor Freight wood lathe. So I hooked the variable speed into the lathe this morning to test that theory. I don't have a tacometer to verify it. How ever it seems to have worked. It does make a couple of clicks but I can only assume that the clicking noise is the variable speed control talking to the motor telling it to spin at a certain speed. Here is the video result of the hole thing. No music just lathe sounds. Almost 2 minutes. So score 1 for me.- 23 replies
- wood lathe
- variable speed
(and 2 more)
Are there any stationary power tools other than a drill press or a lathe that would benefit from continuously variable speed, irregardless of the method?
- 4 replies
- variable speed
- types
(and 1 more)
Continuously Variable Speed Band Saw
Texaswally posted a topic in Machinery, Tools, Research, Reviews and Safety
Would it be of any real advantage in woodworking to convert a band saw to continuously variable speed? This would be fairly easy to do, just change the motor to 3-phase and power it with a VFD. My thoughts are the cost wouldn't justify the change and if it was such a good idea, they would be available commercially.
