Showing results for tags 'tite bond'.
  1. Some of you know that I am building a tool chest. I live in Virginia and winter is fast approach it. We are getting nights in the mid thirties to low 40s now. I would like to finish and by that I mean put a finish on this chest when I'm completed with it. That's going to be another couple weeks at the most. I had planned to use polyurethane. It is pretty much my go-to finish for anything other than musical instruments. But I have a three-fold problem. First of all it's going to take a bit of extra curing time in cooler weather for the polyurethane to dry. Second of all I'm going to have to store it in my shed. No temperature control. So it's a dovetail box held together with Tite Bond. Made from pine. Can that box withstand low 30s temperatures for a couple of weeks? I know that polyurethane only really takes about 3 to 5 days to fully cure, but my wife has a very sensitive repeat that very very sensitive nose. She also has cerebral palsy and it's not just about a dislike of smell, but sometimes really hard pungent or heavy or chemical type smells will throw her into seizures. Even things like the little car freshener Christmas treats things like that. And so I have to leave that in the shed until it is dry and completely cured. My other option is not to finish it at all and wait until winter is over. But I will be carrying it in and out of the house to the back yard where I do woodworking in the meantime. It's going to get dirty and nasty because I'll be working out of it. I would rather not do that. But I work in the wintertime out back on my bench as long as the snow and everything else allows me to do it, even in cooler temperatures. So I need a solution. I need to know if the box will withstand possibly freezing temperatures, I need to know if I can go ahead and use the polyurethane and give it that time or if I need to go to something else. I was considering shellac because you can pretty much throw it under any kind of finish, and I could shellac the box and it would be semi-protected at least until springtime rolls back around. But I do not know how long it takes for shellac to dry so that it has very little smell. It might be the same situation. Any type of advice that you can give me is more than appreciated. Thank you
