Showing results for tags 'smoothing cuts'.
Can you believe it? Tomorrow is the first day of October! One of own, @Charles Nicholls, could use some prayers and good thoughts. Charles is in the hospital and hopefully recovering but if you could take a moment and send some positive energy his way, I'm sure it will be appreciated. A little more information is here- EDIT EDIT EDIT--- Just received word that Charles has been moved from the hospital to a rehab facility. Things are looking up! Our Patriot Turners- Last week @Masonsailor showed us his beginning Christmas present project. He has added even more to that post- @AndrewB must sleep by his lathe . He has completed several projects this past week. First up are a couple of maple bowls- His post explains what he did- Next, he used up some of his scraps and turned a small bowl- Andrew used some of his poplar to turn a couple of bowls. Notice his skill level improves with each project. Check out the wall thickness on these - The astute observer will see that Andrew's lathe went from Wen orange to Harbor Freight green. His Wen lathe was having some issues with losing power and erratic speed control- His HF lathe uses a Reeves drive speed adjustment and doesn't slow down much below 600 rpm's. Andrew experiment with a speed controller but experienced some difficulties. Thank goodness @Larry Buskirk, was around and helped him determine what was happening and why. What’s Coming Up- If this pandemic has had a positive side, it's that woodturners all over the world are turning to virtual demonstrations. Those of us who cannot afford to travel can still learn from their teachings. If your woodturning club is looking for this type of event, Glenn Lucas is offering large group/club instruction. https://www.glennlucaswoodturning.com/product/1½-hour-remote-demo-to-a-woodturning-club/ For The Newbies- Getting the smoothest possible finish, directly from your tools, will reduce sanding time and expense. There are a couple of techniques, using traditional tools, that can really help. Lyle Jamieson demonstrates the "push" and the "pull" cuts Finally, here is an unedited Q & A video from Mike Waldt where he answers some questions about how to hold your work on the lathe- Expand Your Horizons- Really nice, short video from Alumilite explaining the Science Behind Resin: Epoxy vs Polyurethane- Looking to create that one of a kind turning that no one will believe came from a lathe? There is a product called "compressed wood" and it can free your imagination. This article is from is from the AAW AW2906p25-291.pdf Last week we saw a video for turning a "square" bowl. Here, Mike Peace turns a "three corner bowl" New Turning Items- Getting the consistent grind on your gouges can be frustrating. Ron Brown has come up with a set up block to help make repeatable grinds- https://www.ronbrownsbest.com/index.php?route=product/product&product_id=737 Our most generous sponsor, Easy Wood Tools, shared a video from Tracey Malady. She demonstrates the EWT mini hollowers. Thanks @Jim from Easy Wood Tools! Everything Else- Last week's YouTube turning videos from Rick Turns- Ready to ride off into the sunset (baby shower)- Safe turning and stay well
