Showing results for tags 'shaker style'.
Been ripping and a-cutting on a few planks...and a Project has been started... Some of the parts.. Then a few more parts.. Some other parts needed a little help.. So...we help it out a bit..with a bit of Cardio thrown in.. The goal was to get rid of all the wane, and BIG knots...and fuzzy edges... One plank used to be a 1 x 8 x 6'...took a while...but.. One board was rejected..wonder which one? Had a replacement handy... And..just to make the panel a tad wider... That "small knot"? might get shifted to the outside, and then sawn off.. Other parts.. 5/8" thick Soft Maple for the sides and back of a drawer...Ash for the 3 aprons and a drawer front...which leaves.. Needed for of these...to make tapered legs with...let them sit overnight, then... De-clamped them...set up the rip fence to just skim two faces...one to remove the glue lines, the second one was to skim of a face, to get rid of the "Fuzzies", 90 degrees to the first pass Passes #3 and #4..fence was reset to 1-1/2" width...and the other 2 faces were run through... Will have to trim the ends square..then decide which two faces to cut the tapers on... Until then.. I'll leave then clamped together. Need to joint a few edges... And get these 5 glued up into a top for a table.... Stay tuned..
- 43 replies
