Showing results for tags 'pro edge'.
A record of some observations after having an opportunity to use both tools. Tormek Round grinding wheel leaves a radius or hollow grind This is desirable for some applications like a parting tool. Does a great job on gouges Hollow grind is less than ideal for bench chisels and plane blades Time Takes longer to sharpen Preparation Since the diameter of the wheel changes with use, set up is inconsistent from session to session. Jigs and notation labels on the tool help to mitigate this, but still requires fiddling each time you return. Steel stays cool Re-grinding bevel takes an excessive amount of time. Tool not really designed for this work Cost Very expensive, in excess of $1000 Long term More expensive to operate over time due to high cost of abrasives An assortment of grits requires significant investment in stones. Adaptability Jigs are available for a WIDE variety of edged tools from Axe to Scissor. Sorby Pro Edge Platen is flat and leaves a flat surface Ideal for skews, bench chisels, plane blades Does a great job on gouges Time Quick and easy changes between abrasive grits Coarse grit belts allow for quick regrinding Belts are available to allow for a very high polish 320 grit is good enough for lathe application Heats the steel Cool steel by dipping in water as needed Consistent distance to platen Jig is consistent each time you return to sharpen Quick and easy with no fiddling Notation label with wing angle, protrusion, and hole allows for fast easy setup upon return. Required after market accessories for lathe tools. https://www.amazon.com/Robert-Sorby-Proedge-Proset/dp/B008AK7ULO/ref=pd_sbs_1/132-8175967-9286741?pd_rd_w=7PClz&pf_rd_p=0f56f70f-21e6-4d11-bb4a-bcdb928a3c5a&pf_rd_r=9ZMT2EMRXCCZXWEF8G4T&pd_rd_r=8854af3f-d351-402e-a86f-914ddc6c1f17&pd_rd_wg=3iG5v&pd_rd_i=B008AK7ULO&psc=1 https://www.amazon.com/Robert-Sorby-Proedge-Long-Grind/dp/B008AK6HQ8 Cost About half the cost of the Tormek Long Term Belts run less than $20 and last a long time Adaptability Available jigs are limited to wood working tools .40
