Showing results for tags 'plane til'.
Found 2 results
  1. steven newman
    The Tool Chest, a $0.05 Tour
    Tools have been put away...until needed. More of a "Ready Rack" for the most used saws in the shop....Time to open the doors for a look around? The Left side..and the Right side...a little further to the right... Is the Main Plane Til.... Just a quick look around...unless someone wants "close-ups"...
  2. steven newman
    Planes...just,....planes
    Like the title says.. Some have already seen this plane til....those block planes across the top? Are the main users. Half are low angle ones. Some of the "special" planes. The old block plane is great for knocking off excess dried glue.. There is one thing about these wood bodied planes...they weigh a bit less than the iron versions. That red jack? That is my "scrub" plane. The Big Guys. The Millers Falls #14 because it is used as a big smooth plane. A #8, another #7, and a #81 try plane. You need your Wheaties, before a full day of moving these around..... Somewhere in the shop, there is a third spokeshave.....I tend to treat them as planes. The #45....7 planes in one. IF anyone wants to see what is on that shelf.....I might bring them out into the daylight. Depending on the project, there are 6 or 7 planes that always seem to get used..... Depending on the size of the project....some will get swapped out for another size. The #7 may turn into a #6, or a #5-1/2. The #4 may get changed out to a #3 size. That #5 may get replaced by the 5-1/4 as a jack. The #5 has a bit of camber to the edge of the iron, the 5-1/4 does not. After a long day of pushing planes around...smaller ones tend to come out....old arms tend to get tired.
