Showing results for tags 'painted saw'.
Yep, you see something like this about all the time.. AND..they seem to think these should cost more than... Than that Stanley 14" one... Whatever paint they use on these things...it is a ROYAL PITA to get back off of the plate... Saw nuts were removed..and polished back up...Handle was removed for a while.. 80 grit on the Palm sander, then 220 grit, then 1500 grit...took a LONG time...before.. Steel back had slid down on the plate,, had to adjust it back out a bit.. Any etch was silk screened on, anyway..so that was long gone... Time to hang this up in it's new home sweet home? Before I added the handle back on, I gave the steel parts a rub down with the 3in1 oil.. I MIGHT have too many backsaws? Nah...
