Showing results for tags 'live edge shelf'.
From the album: Live Edge Walnut Shelf No. 1
A bit of planing and scraping.© The Patriot Woodworker
OK, we're getting somewhere. But what finish do we want?© The Patriot Woodworker
The Rubio Monocoat finally arrived! Bracket attachment points were marked, taped off, and sanded prior to bracket gluing.© The Patriot Woodworker
Still lacking one bit of hardware . . .© The Patriot Woodworker
. . . but have time to admire the edge while waiting for . . .© The Patriot Woodworker
. . . the mortise keyhole hangers!© The Patriot Woodworker
Done. Two long screws run diagonally through each bracket into the top, though I doubt the glue will ever fail. Screw heads are well countersunk, the holes patched with walnut shaving & Titebond filler. 1/16" sheet cork applied by adhesive to protect mounting surface and eliminate noise in the event a hollow wall + vibration occur.© The Patriot Woodworker
Indirect sunlight dawn photo shoot.© The Patriot Woodworker
And that's it. Thank you for viewing! - jim© The Patriot Woodworker
