Showing results for tags 'golden mean'.
Our Patriot Turners- A little bit more happening this week! Long time member @Steve Krumanaker is still making items for a local artisan. He showed us the wooden lids he turned for herb jars- Steve's lids include a metal lid inset. He tells us more about these and some of the other types he turns in this post- We also had an entries in the "What's On" and "What's Off" posts. A red oak medium sized bowl and a smaller bowl What's Coming Up- Cindy Drozda was at SWAT. Wonder if @Gerald talked with her? Cindy did a walk about and posted it on her YouTube channel- She also posted the video of of the bowl turning battle between Mike Mahoney and Stuart Batty- And, Cindy has a Tool Talk coming up this Friday. Click on the image for the link to registration. For The Newbies- An article, from Fine Woodworking, reviewing midi lathes. If a full size lathe isn't in your budget or you have a very small shop, this might be helpful. https://www.finewoodworking.com/2023/10/27/tool-test-midi-lathes-2 Tim Yoder shows us a less expensive way to sand some of those turning projects- Expand Your Horizons- Mike Peace dives into buffing. In this video, he demonstrates the use of the Beall Buffing System. I usually put Ron Brown's newsletter thoughts at the end of our Wednesday's post. Ron's thoughts, this time, really fit into expanding your horizons. Correct Proportions Help Make A Pleasing Shape The Golden Mean, also known as the golden ratio, golden section, or Fibonacci rule, is a principle of design that can be applied to wood turning to create objects with proportions that are considered aesthetically pleasing. The golden ratio is approximately 1.618. This ratio is found throughout nature, from the spirals of a seashell to the branching of trees. Artists and architects have used it for centuries to create a sense of balance and harmony. Applying the Golden Mean In wood turning, the golden mean can be used as a starting point to determine the proportions of various elements of a turned piece, such as: • Height to Diameter: For a vessel like a vase, the golden mean can guide the ratio of its height to its widest diameter. For example, if a vase is 10 inches tall, the golden ratio suggests its widest point should be approximately 6.18 inches (10 divided by 1.618) from either the top or the bottom. • Dividing the Space: The ratio can be used to divide the bowl's form into different sections. For instance, the ratio of the bowl's base diameter to its rim diameter could follow the Golden Ratio. This would create a pleasing visual progression from the bottom to the top. • Location of Features: The golden mean can also be used to position design elements on a turned piece. For a hollow form or vase, it can help determine where the widest point should be located to create a visually appealing curve. Similarly, on a wide-rimmed plate or bowl, it can guide the size of the central bowl in relation to the overall diameter of the piece. • Proportions of a Foot: The size of the foot or base of a bowl can be determined using the golden ratio in relation to the bowl's overall diameter. This helps create a stable and visually balanced foundation. • Proportions of a Finial: A finial is typically composed of several distinct segments, such as a base, a sphere or urn shape, and a tapering spire. The Golden Ratio can be used to determine the ideal proportion of these segments to each other. For example, a designer might ensure the ratio of the total length of the base section to the total length of the tapering section is approximately 1:1.618. This creates a natural-looking visual flow, preventing any one part from appearing too large or too small. Tools and Considerations Woodturners can use golden ratio calipers to apply this principle to their work easily. These calipers are designed to maintain the golden ratio as they expand and contract, allowing the turner to quickly check and adjust the proportions of their piece while it is on the lathe. Trent Bosch* offers high-quality Golden Mean Calipers HERE. Prices range from $40 to $175. While the golden mean is a powerful design tool, it is not a strict rule. Many turners find that using the golden ratio as a starting point or a general guideline helps them create pieces that feel "right" to the eye. It's important to remember that design is also about personal preference and artistic expression, and a piece can still be beautiful and well-proportioned without adhering strictly to the golden mean. Some artists prefer a more intuitive approach, relying on their "eye" and experience, which may lead to proportions that are very close to the golden ratio without any deliberate calculation. Trent Bosh also offers an excellent visualization with several examples for using the Golden Mean Calipers in this 8-minute Video.* There are several YouTube videos that show you how to make your own calipers if you prefer. Turning Time With Easy Wood Tools- Some great savings on those easy wood tools! https://www.thewoodturningstore.com/?srsltid=AfmBOorjI1m11YEv2ly3Mt17JasshNCyx_w_aMJ90hXPCw-n3_zvdwVW A couple of demos in early September- https://www.rockler.com/retail/stores/fl-altamonte-springs-store?utm_source=local&utm_medium=organic&utm_campaign=altamonte-springs https://www.rockler.com/retail/stores/az-phoenix-store?utm_source=local&utm_medium=organic&utm_campaign=phoenix From Nathan McCollim demonstrating how "Easy" it is to learn turning with Easy Wood Tools! AQMcZvOK77-bg2XUyRjjsDUvwMhM0RPXER-BLRMnv2rqtzSRtJYH0qiEObuzn1g9o0tbfzxDORcVk3Ishka-KiV7eMgD5_TG4X3MLWQ.mp4 @Jordan Martindale New Turning Items- Definitely not new but relates to Ron Brown's thoughts on pleasing proportions. https://trentboschtools.com/product/golden-mean-calipers/ Everything Else- Safe turning
