Showing results for tags 'egg beater drill'.
  1. have a pile of auger bits laying around, getting beat up. Got to do something about that. Had a 2x4 of pine. Planed until squared up. laid out a center line between the two knot infested areas. Chucked up the largest bit in to a 10" brace. Turned out to be a might small, but i drilled a hole anyway. Kept changing out for the next size smaller, until a tiny #4 was used. A #4 is 4/16" in diameter. largest was a 20. There was even an expansion bit, not a very good one, but it worked. Yeah, yeah, a bit of a blowout on the big one. Most are as deep as I could get them. Might chase the holes with the Forstner bits, to make pulling then out easier. You see,they sit like this lovely sight, ain't it? anyway, I'm building a tray-like contraption to hold this strange looking thingy A bit of Barn Siding stuff, the 2x4 rack, and a plywood filler. Plan right now is to make the rack pivot like any other Drill Index. Then lay back down into the tray. Might get two pivot pins, might be two hinges. Won't be some fancy-schmanzy dovetailed tray, either. Have a whole series of trays planned. Lots of files and rasps to find a home for, lots of screwdrivers, pliers, wrenches, and other doo-dads. Might even make something to house these clowns, too All Jack planes. 5 #5s in the middle, a 5-1/2 on the left end, a 5-1/4 SW on the right end. Might have enough of these? Then, there are a few drills Two of the three braces, and an eggbeater. Getting a might crowded down here?
