Showing results for tags 'curved sides'.
Found 6 results
  1. Lumber Run the other day...one of the boards was a1 x 6 x 6'5" plank of Maple....the other Maple was even longer...decided to see about a Project for October.. Sides are curved.. Fancy stuff.. However...sides needed to be 9/16" thick, not the 3/4" that the Maple was...lid panels are at 5/8" thick...need to do some resaw, it looks like. Hauled that plank to the shop, once the bench had been cleaned off.. IF I can hit me head on the way down the steps...imagine what this was like...had a few spots to work around, too.. Usual knotty stuff.. Even a "split end" Went to the cutting list...and started to lay out what needed to be cross cut.. Board was a wee bit too long to be cutting on the tablesaw, so.. we have ways..Disston D-100, just need a cut line to follow.. And work my way along until.. Left-overs? Will provide a 9/16" x 4" x 6" piece for the end of the box, to go with these.. Includes a "spare" side...but, these are all too thick...need to set up a kerf cutter, again.. Best face against the fence, run all 4 edges through...fence set at just over 9/16" for some cuts. and 5/8" for two others..blade does not reach high enough.. But, this will...just follow that kerf.. Until... "POP"...Repeat for the rest of the sides.. Will work on the other 3 parts later...will need to plane these smooth.. Before any joinery can start in.. Stay tuned..
