Showing results for tags 'box building'.
There is a Pine plank just sitting around...starting to get quite a twist to it. 1/2" x 6" x 6"......thinking I can cut it up into the 6 parts to build a box...using just hand tools? And maybe post a bunch of photos on HOW such a thing can be done? I MIGHT use the bandsaw for one task, but that would be about it.....all the rest will be by hand...and using just that one Pine plank. Not sure IF I should post it here....or..up in General Woodworking? Or both? Stay tuned...camera is charging up at the moment...
- 16 replies
- hand tools only
- box building
(and 1 more)
Laundry Detail to night, had to kill a little time for the dryer to get done.. cross cut and ripped a few pieces of 1/2" poplar... 2 longer ones for the sides... The other two are for the ends....wanted them all the same width..so.. meet Junior....Junior Jack plane, that is. Boards were a tad too short for the longer Jacks...been a while..had to back off the cut quite a bit, from the last time it was used. Chisel selection? We'll see which ones get into the case. Depends on HOW I lay them in there, and what holders I cobble up....1/4" plywood top and bottom panels...and will saw the lid off, again.. Wonder which joiner joint I'll use.....hmmm...maybe a step by step photo blog? Sorry, no fancy-schmansy "timber" available.....Poplar is good enough for shop storage, anyway. Stay tuned
- 20 replies
- box building
- chisels
(and 1 more)
