February 3, 201412 yr comment_5385 Got to start somewhere. Breaking down a couple of 4/4 x6 x8' Walnut planks. Cut a few down to match the raised panels I made a while back. Cleaned up the rough sawn edges a bit, and marked them for a rip cut. After a rip down the middle, these will go on the ends, to house them raised panels. Going to get these to a somewhat finished sized, and then smooth the faces up. Less to plane, that way. Tried to handsaw these boards down, ran out of breath ( COPD??) so an OLD Sears Craftsman Circular saw was used. It will also do all the rip cuts. Corner posts were straight edged up. Then set up for a rip down the middle. I'll then add a Tongue & groove joint to the edges of the corner posts. Report
February 3, 201412 yr Author comment_5393 Making rabbets, the easy way Grooves on the other hand, ain't so simple. Tried a router with a 1/4" straight bit. Bad news? It had a 1/2" shank. Got about halfway along on one of these stiles, and SNAP went the bit. Tried the handsaw/chisel routine, too much work! Went back to the router bit box. Found a round nosed bit, with a 1/4" shank. Found the 1/4" collet as well. Hey, hands were a bit shakkkkyy, OK? This is the set up. Learned the hard way which way to run the router along an edge, too. ( both "blow outs" will be on the inside, thank you) again a bit blurry from the shakes, but this gives an idea on how the sides will go together ( I hope) Two panels held by three stiles. Corner posts will be two pieces, joined at the corner. Will also be cutting a "foot" detail, just to keeps thing off the floor. Have the edges planed square and smooth, will work on the faces when things are a bit closer to final sizes. Smell of Black Walnut......NOT even close to Aromatic Red Cedar! This stuff STINKS. Looks good, just don't smell good... Report
February 3, 201412 yr Author comment_5392 As for ripping things to size May not be a Unisaw, but this does fit in the Dungeon Shop. Saw says Sears Craftsman on it. All metal, too. As for them handled items in the background? Could a handplane or two??? Report
February 3, 201412 yr comment_5391 Wow Steve, I would have been out of breath too and sore armed. Looks like you got it going your way though. Beautiful walnut. Report
February 4, 201412 yr Author comment_5390 Worked on the corner posts a bit, too. Had to use a "modern saw", though Seemed to work ok, though These will make four corner posts. Lay out was too bad Then used an old Jack plane to even the edges up Walnut curlies, anybody?? Report
February 4, 201412 yr comment_5389 There is no safe wood in this world as along as Steve is walking the earth! Go Steve!!! Report
February 4, 201412 yr Author comment_5388 Let's see if some more will load Don't have a wagon vise, but there is a plane stop style of bench hook. Added a bit of scrap to one side, and a screw on the other. Plane the face grain nice and smooth, even that big old knot. Needed to get them like this, as I have to reference of them for the grooves to be cut. Some of the boards were just a wee bit out of square. Mark a line and jointah plane down to it. THEN I could cut out a few more rails, and size them down as well. There MIGHT be one board that MAY be safe from me This is about 6" wide, by 24" long. What do I do with something like this? There is a way to do skinny boards on edge Place a C clamp to hold up one end, and tap the other end into the Crochet. Then plane to a line. Parts are starting to pile up, now, might get to glue some together next week??? Report
February 7, 201412 yr Author comment_5387 Test of a test fit photo. Test fit didn't go too well, have gaps. Will tear down and adjust, WHEN I get a little time from work. the culprit seems to be these grooves. Just enough off-center. Can go back a center them a bit. Raised panels aren't seating into the grooves. Still an 1/8" in the bottom of the groove clearance. It isn't the tenons' fault, I cut them to fit using the latest mitresaw I have Oh well, I quess that is why we have test/dry fits in the shop... Report
February 7, 201412 yr comment_5386 Man you got the curls going. Watch out in the dungeon, Steve is mad at work! Report
November 18, 20188 yr Popular Post comment_166959 Obvious Steven was still evolving in this thread. The use of tools with those long black tails has faded Report
November 19, 20188 yr Author comment_167019 This Tool Chest has been re-purposed into a Blanket Chest by the Boss. A tall, 5 drawer chest of drawers has taken it place in the shop. Guess I kind of out-grew the chest? Report
November 19, 20188 yr Popular Post comment_167020 47 minutes ago, steven newman said: A tall, 5 drawer chest of drawers has taken it place in the shop. Guess I kind of out-grew the chest? Sounds to me like a classic case of "Furniture Disease..." ...You know, where your chest falls into your drawers Report
November 19, 20188 yr Popular Post comment_167021 1 hour ago, Grandpadave52 said: ...You know, where your chest falls into your drawers I always referred to that as Dunlap's Disease, where your stomach done-laps over your belt. Report
