August 9, 201412 yr comment_515 Last end panel was out of the clamps, so Drill about seven or so counter-bored holes per corner, and try to put this thing together, Seemed to work better on it's top for this part, There is some wood putty that needs cleaned up Once all the corners were screwed together. Added those plastic white feet to the corner posts. Might keep the feet a little dryer... adding a cleat or two to set a floor on. Stay tuned, finish line is in sight....I hope. Report
