Laguna Platinum Series 16-43 Wood Lathe (1.5 HP, 115V) - $880 (San Jacinto, CA)
Selling a Laguna Platinum Series 16-43 Wood Lathe (Model: MLA0230-175) in great working condition. This is a heavy-duty, cast-iron machine built for both spindle turning and larger bowl turning.
Key Specifications & Features:
Motor: 1.5 HP, 115V / 60Hz (Runs on standard household 110V outlets)
Capacity: 16" swing over bed / 43" distance between centers
Headstock: Swivels (0°, 60°, 90°, 120°, 180°) for out-board bowl turning
Speed Control: Mechanical variable speed control knob
Base: Heavy cast-iron legs and bed for solid stability and minimal vibration (~300 lbs total weight)
Includes: Spur center, tailstock live center, tool rest, and original cast-iron legs (as shown in photos).
Condition: Clean, solid, and fully operational. Belt/speed adjustment operates smoothly.
Pick-up: Local pick-up only. The lathe is located on ground level in my garage for easy loading. Please bring a suitable vehicle/truck and I can help lift (~300 lbs).
11 minutes ago, lew said:
Looks brand new!!!
Pretty low hours Lew.
