January 27, 20251 yr Popular Post comment_350739 A member of the club turned an inset for a handle and since aluminum is cheaper than buying an insert I decided to give it a try. Bought a 1.5 inch bar on Amazon. Cut off 5 inches. Chucke it up in 35 mm jaws. Drilled a thru a hole I think it was two sizes over 3/8 so tool can be reversed. Picked what I thought was a nice piece of pecan but the holes running down the side were nothing compares to the one I almost center of end so that is the end chucked. Drilled 3/4 for insert and then. 7/16 deep enough for the gouge to go in almost completely. Turned the handle just a little larger than most others. Not as easy to turn aluminum as you might think. Wish I had bought 1 inch Aluminum. Edited January 27, 20251 yr by Gerald Report
January 27, 20251 yr Popular Post comment_350742 Will there be screws added hold the tool bar? Report
January 27, 20251 yr Popular Post comment_350743 I like it. Looks great. Aluminum is a lot harder than wood. Keeping the tool in the cut is difficult because of the hardness. Report
January 27, 20251 yr Popular Post comment_350745 There was an article in the AAW magazine some time back by a guy who opined that woodturners should also have a small metal lathe. I've toyed with that idea over the years and never pulled the trigger. I would know less about using a metal lathe than I do with a woodturning one. Still, there are quite a few times i wish i had one. Back to your handle, I think that really came out nice. Like Lew, I was wondering about set screws. Report
January 27, 20251 yr Popular Post comment_350750 I have put mine to use quite a few times making tools. Report
January 27, 20251 yr comment_350789 Well done Gerald. Kudos for doing something beyond the "norm." Surface finish came out very nice on the inset. Report
January 29, 20251 yr Author comment_350901 I had not tapped for screws when pic was taken. That was the easiest part of the whole thing. The Al rod 16 inches was just over 20 , so that is enough to make 3 inserts. Lets see at 20 to 25 each to buy it adds up rather quickly. Thanks Edited January 29, 20251 yr by Gerald Report
