November 4, 20242 yr Popular Post comment_345590 Microsoft reminded me of "memories of this day" for a fix I did years ago. There obviously was some sort of solvent (most likely nail polish remover, a kind of lacquer thinner, usually) on a dining chair. The fix was just to apply some clear touch up lacquer, let if dry, probably with some help with a hair drier. That just took a minute or two. Do some light sanding. Repeat until it's level and color returned. Sometimes, you need to apply a final coat of lacquer over the whole thing to match the sheen. Lacquer will dissolve layers below, essentially making one layer of finish, unlike other finishes like oil and waterborne poly where the layers are always distinct. They also take much longer to dry, so a quick on-site fix is not possible. In my 20 or so years of furniture repair, I think I had 3 pieces that were not factory finished with lacquer of some sort. Report
November 4, 20242 yr comment_345616 Wow, That is amazing!! I have never mastered spraying lacquer Report
November 4, 20242 yr comment_345618 1 hour ago, lew said: Wow, That is amazing!! I have never mastered spraying lacquer Me either, always a challenge Report
November 4, 20242 yr Author comment_345629 6 hours ago, lew said: Wow, That is amazing!! I have never mastered spraying lacquer This, and burn-in repairs, were done 4 or 5 times a day many days. Also in the portfolio was cleaning upholstery. Less common, but always in the job list, fixing upholstery by sewing, fixing power and manual recliners, and what I called "structural repairs", stuff like broken or separated wood parts. I also did a lot of strip and refinish and kitchen cabinet refreshes. Never a dull moment. Report
November 5, 20242 yr comment_345643 Great job on the chair. For me Lacquer was difficult before I discovered that a small bypass airbrush from Harbor works very well with lacquer. The key is to apply enough to wet the surface but not so much that it is oversaturated and runs. Yes I know that sounds impossible and it is a learned thing but it just takes practice. Report
