August 21, 20242 yr comment_340865 August is coming to an end. Our local schools start back tomorrow. Our Patriot Turners- We have a new member at the Patriot site. @Gordon joined this week and posted some of his turnings. He does some beautiful work! If you haven't already welcomed him, please take a minute to stop by his post and check it out! @AndrewB continues to rehab his shop and posted some more images of what he is doing. Pick up here from last week- What’s Coming Up- If you missed Cindy Drozda's most recent live tool talk, she uploaded it for replay- For The Newbies- Mike Peace demonstrates turning a clamshell. During the turning process, Mike encountered some grain tear out. He has a pretty neat way of handling the problem. His solution is at about 9 minutes into the video. Captain Eddie posted a short video on the importance of keeping the lathe's Morris tapers clean- John Lucas discusses techniques for sanding the inside of hollow vessels Expand Your Horizons- Lyle Jamieson provides tips on matching grain between the bottom and top of a turned lidded box and why grain orientation is important. When I learned to turn bowls I used a mortice to hold the blank to the chuck. It just seemed that it wasted less material on the bottom of the blank. I could easily convert the mortice into a foot for the bowl. Alan Stratton uses a similar technique to turn a Sapele bowl- How about embellishing your turning with clouds! Tim Yoder shows us how- New Turning Items- Last week we posted a link to the Niles Bottle Stoppers tenderizing kit. Since then, Carl Jacobson produced a video on turning handles for those items- Everything Else- From Ron Brown's Newsletter= The Difference Between Perfect And Good Enough Perfect Definition: “Having all the required or desirable elements, qualities, or characteristics; as good as it is possible to be.” In life, things are seldom perfect. When turning wooden objects, things are rarely perfect. I recommend that you strive to be better this time than last time. Three main areas within your control always make a huge difference in the final product and require surprisingly little extra effort. Shape Learning what shapes are pleasing is a lifelong quest for most of us. When you are making something for someone other than yourself, you have to consider the shape. It must be visually pleasing with the proper proportions. The curves must be fair and the separations must be sharp. A great way to develop an understanding of pleasing shapes is to study ceramics and glass vessels similar to the projects you undertake. There are tons of resources on classic shapes that have been around for centuries. There are good reasons for certain shapes to remain popular over the centuries. If you try to swim upstream for too long, you will soon tire and fail. Sanding This is an area most easily and quickly improved. 1) Half a Grit: if you start with 100 grit sandpaper, don’t go finer than 150 grit next. Then don’t go finer than 220 grit and so on. 2) Take time to visually inspect that all of the 100 grit scratches are removed before you finish with the 150 grit. If you don’t remove all of the scratches at each step, they will show through in the final finish. 3) I recommend using compressed air to blow off all of the sanding dust along with a strong raking light to inspect your work before moving to the next grit. If you are working with very hard wood i.e. ebony, cocobolo, African blackwood, padauk, acrylic, or epoxy, this is especially important. Take extra time to get it right now or you will have to do it over. 4) NOTE: I stop sanding wood at 320 grit. When using finer grits, friction can overheat the lignin in the wood and make it resistant to film finishes adhering to the surface causing the finish to fail much sooner. Finish 1) If you rush the finishing process, you will have ruined all your hard work. 2) Film finishes (lacquer, varnish, shellac, epoxy, friction finish-shellac) are more durable than wax finishes. But they take more time and effort. 3) Wax is a quick finish that will dull over time and need to be renewed either by reapplication or more buffing. Wax finishes are quick to apply and look shiny and sparkly in the short term. Wax is perfect for projects where saving time is important and the durability of the finish is of no significance. Wax or oil is mandatory for utility vessels such as salad bowls or kitchen utensils. 4) Multiple coats of lacquer (10 to 30) applied over several days and when allowed to cure for 30 or more days, can be polished to a brilliant mirror-like finish. This is the finish of choice for art and display-only pieces bringing top dollars such as in a gallery. Try to do better each time than the time before and you will quickly reach Master Status Skill Sets. Consider the end use for what you are making and decide how much time you can devote to making something perfect or just good enough. Safe turning Report
August 22, 20242 yr comment_340867 Thanks for the post Lew. Tim Yoder posts some short videos on FB you might want to check those out. https://www.facebook.com/reel/1047039867087617 Report
August 22, 20242 yr comment_340877 Thanks Lew. Glad you're always hunting down the latest turning videos and other content. I like viewing them. Report
August 22, 20242 yr comment_340880 Thank you for the introduction and the great collection of information. Report
