JaHo jig project
First project on a bowl . Wood is Spalted Bradford Pear and I was well pleased with the results of dying. Applied lacquer to bowl after dying. The the black liming wax goes in the cuts made by the jig. These are before and after pics. IMG_8782.jpeg.27e60188f7cddcd67de27d013872b90c.jpeg
Now which do you prefer?
I like the bottom one better.
You have it down pat now.  Looks good.
Us there much vibration from the cutter?
Edited by HandyDan
Love the dye color with the spalting. Gives it a real emerald look.
Second one for me three.
It is a matter of eliminating one problem at a time. The wood used also makes a difference. Did not want to tie up my faceplate all the time but it may reduce the vibration a bit more. At this stage slow and easy works well, Thanks to all
Yeah, the bottom one has a better look. They are both really cool however.
That's pretty awesome! The bottom one has more visual impact for sure.
Wow Gerald, that's super.  And, I like the bottom one better also.
Yes sir, that is some fine work there. I might have to try some dyes now. I have some gears turning in my head. I'll have to get back to you guys after some experiments.
