Cutters for ez wood rougher
I need to replace the cutter on my EZ wood rougher. The one I have (I bought this tool used) is an R2. In trying to find the significance of this I see there are 3 different radii offered...a 1", a 2" (mine) and a 4". Is there a reason to buy a different radius than the 2" I have? I tried to find this on the web and did not get the answer to my question, though there was a number of videos about them.
The 1 would leave sharp 90° corners
The 2 would leave rounded or softer corners.
The 4 has a radius and would leave a potentially better finish but would not do sharp 90° corners well.
If using it for roughing I would get the 1 or 2.
Fred,
This PDF is a list of all the Easy Wood Tools cutters.
For the rougher, as @Grandpadave52 indicated, the Square (Ci1-SQ) is mostly used for tenon making and spindle roughing. The Ci1-R2 can be used for tenon making or smoothing.  The Ci1-R2 and Ci1-R4 have rounded corners where as the Ci1-SQ has 90° corners. The "R" -radius- value is the arc amount on the cutters 4 sides. R2 is slightly MORE rounded then the R4.
I find the Ci1-R2 is great for smoothing the outside of a bowl. The slight radius and rounded corners help reduce catches and tool marks.
Let me know if you need more information.
Easy Wood Tools Carbide Cutter Guide - 2-23.pdf
I wish I was that smart, but alas not to be.😜 @HandyDanis the smart one especially on this topic.
 Apologies to you both and no insults intended. I'm the idiot...
No worries here.
So are you saying now, you agree I'm not the smart one?:rolleyes:
Edited by Grandpadave52
  • 2 weeks later...
I just recently bought 10 of the 15 mm square radius ones from a website that I found on another forum they were 19.99 for 10 and free shipping. I am currently using one and it works great. Very happy with them.
Edited by keithlong
I don’t use carbide very often but when I need a new cutter I buy them from AZ Carbide.
