January 10, 20242 yr comment_327612 I have a plate to mount but it has .350 dia thru hole with 82 deg countersink. Supposedly for #12 or #14 screws but no vix bit for that size hole is available. So how to accurately find the center of the hole? The #12 screws fit but are recessed below the surface of the plate which is desired. Note even sure if #14 screws exist maybe it is then measured as 3/16 or 5/16 or just what is the next size up. Any ideas on how to find the exact center of the holes? There are 6 of them in the plate and I am to make sure the plate is parallel to the bench. but any little 1/64" off center and it does not work. Any and all help appreciated. Report
January 10, 20242 yr comment_327614 Could you turn a round, pointed piece that would match the 82° angle. Put some pencil graphite on the tip and use it as a marker? Report
January 10, 20242 yr Author comment_327617 40 minutes ago, lew said: dowl in drill press with a file/sandpapre to shape I could use the plate and one hole to shape the dowel. CS side up but then how am I shure which i round off the tip that I centered it. I would guess the spinning action of the DP may work just not as precise as I would like but I will try it and let you know. Report
January 10, 20242 yr comment_327618 5 minutes ago, Michael Thuman said: I could use the plate and one hole to shape the dowel. CS side up but then how am I shure which i round off the tip that I centered it. I would guess the spinning action of the DP may work just not as precise as I would like but I will try it and let you know. Picture? maybe I'm not following what you are trying to do. Report
January 10, 20242 yr comment_327619 Would one of THESE work? Stanley used to make a similar version. I have one of those. Report
January 10, 20242 yr comment_327646 Well, there is this....better hurry, only 2 left in stock. They will probably still be there though at that price. Report
January 10, 20242 yr comment_327648 .350" hole might be pretty close to the OD of my routers template guide I use for 1/4" shelf pins. If it were the correct size a veining bit in the router with a plunge base would be spot on. Or, our local Ace carries a pretty good selection of nylon sleeves/bushings that a caliper might find one with a .35 OD, or if it was slightly larger could be chucked up in the drill press and sanded down. Giving you an ID that would work with a pencil or other tool on hand. How many holes do you have to drill, and in what material? Report
January 10, 20242 yr Popular Post comment_327659 See if a socket from a 1/4" drive socket set might fit the hole and go through the center of it. Find a small washer. If it fits anywhere on the taper you should be able to center it on the taper. Once it is centered drop a piece of clear tape over it to hold it in place while you use it. Report
January 10, 20242 yr comment_327675 14 hours ago, Grandpadave52 said: Would one of THESE work? Stanley used to make a similar version. I have one of those. Material Plastic SERIOUSLY????? Edited January 10, 20242 yr by HARO50 Report
January 10, 20242 yr comment_327684 1 hour ago, HARO50 said: Material Plastic SERIOUSLY????? Can't believe everything on the internet. Abraham Lincoln GENERAL TOOLS AUTOMATIC CENTER PUNCH Report
January 10, 20242 yr Popular Post comment_327685 Well, crap. I have (had) one of those punches Dave linked. I was looking for it to measure the diameter of the barrel. I know I put it back exactly where I could find it the next time I needed it....and it wasn't there. I'm still looking. Edited January 10, 20242 yr by Fred W. Hargis Jr Report
January 10, 20242 yr comment_327686 2 minutes ago, Fred W. Hargis Jr said: Well, crap. I have (had) one of those punches Dave linked. I was looking for it to measure the diameter of the barrel. I know I put it back exactly where I could find it the next time I needed it....and it wasn't there. I'm still looking. Have you looked in the last place yet? It's probably there. Report
January 10, 20242 yr comment_327687 11 minutes ago, Fred W. Hargis Jr said: Well, crap. I have (had) one of those punches Dave linked. I was looking for it to measure the diameter of the barrel. I know I put it back exactly where I could find it the next time I needed it....and it wasn't there. I'm still looking. I have two of them (one Stanley; one General) and I can go locate them now; in a little red plastic box with my old school nail sets. The sad thing, I never remember I have them when I actually could use them or when I read this thread. I'll be digging through my tool box "wonder what's in this little red box? Oh yeah, I could have used that when...." Edited January 10, 20242 yr by Grandpadave52 Report
January 10, 20242 yr comment_327690 2 hours ago, Grandpadave52 said: Can't believe everything on the internet. Abraham Lincoln GENERAL TOOLS AUTOMATIC CENTER PUNCH Oops wrong tool. I meant THIS Report
January 10, 20242 yr comment_327693 2 hours ago, Fred W. Hargis Jr said: Well, crap. I have (had) one of those punches Dave linked. I have one too. My mind says I know where it is so I'll look later. Seems to me it is the same size as the Vix Bits. Report
January 10, 20242 yr Popular Post comment_327694 3 hours ago, Fred W. Hargis Jr said: Well, crap. I have (had) one of those punches Dave linked. I was looking for it to measure the diameter of the barrel. I know I put it back exactly where I could find it the next time I needed it....and it wasn't there. I'm still looking. Well, waddaya know! Mine was in the first place I looked. That don't happen often! Anyway, the tip on mine is just a hair over 1/4". Hope that helps. Report
January 11, 20242 yr comment_327696 3 hours ago, HARO50 said: Anyway, the tip on mine is just a hair over 1/4". Hope that helps. Mine too. Same as the Vix Bits. Report
