August 19, 20233 yr Author Popular Post comment_319637 15 minutes ago, Al B said: Hey John. I guess it helps to have these woodworking plummers on board. Yes sir it does!!!!!!! Report
August 19, 20233 yr Popular Post comment_319646 I was going to say check the aerator but you got it fixed. Have to clean ours once in awhile. Report
August 20, 20233 yr comment_319657 15 hours ago, John Morris said: I don't know why I do this most the time, I'm pretty good at fixing things but I automatically go straight to doom when these issues arise, That.s me as well...must be something in our genes that make a lot of us do that. Report
August 20, 20233 yr Popular Post comment_319664 16 hours ago, John Morris said: I don't know why I do this most the time, I'm pretty good at fixing things but I automatically go straight to doom when these issues arise, Maybe because,... Report
August 20, 20233 yr Popular Post comment_319668 16 hours ago, John Morris said: Then I started looking closer inside the nozzle and saw a piece of black rubber stuck in the 1/4" diameter filter connection and it was plugging up the works.-------it detached from somewhere and shot up into the screen and plugged it all up. John --, in my limited experience with changing out plumbing----sometimes the washer in the shut-off valve dislodges or breaks and when you turn the valve back on the piece migrates up the line. A quick check is to turn the shut-off back off and see if you still get a flow from the faucet. if yes, then the washer is shot. if no, then you had a different problem. Along the same line---the screw that holds the washer usually corrodes to the point that it doesn't hold the washer. Removing the stub of the screw is a real PITA. Report
August 20, 20233 yr Author Popular Post comment_319674 1 hour ago, smitty10101 said: sometimes the washer in the shut-off valve dislodges or breaks and when you turn the valve back on the piece migrates up the line. A quick check is to turn the shut-off back off and see if you still get a flow from the faucet. if yes, then the washer is shot. if no, then you had a different problem. I'll perform the check Smitty, thanks! And hey, great to see you around here again!!!!!! Report
August 20, 20233 yr Popular Post comment_319698 20 hours ago, DuckSoup said: I believe @Gunny calls it "paralysis by analysis". That would seem to be a most Gunny like saying! Report
August 20, 20233 yr Popular Post comment_319699 My mind (alleged as it is) works slightly differently. I would be telling my family that the water bill had gotten high enough that something had to be done about it, and it was a water savings faucet I installed. Report
August 21, 20233 yr Popular Post comment_319740 11 hours ago, John Morris said: great to see you around here again!!!!!! I haven't ever left!! Report
September 16, 20233 yr Popular Post comment_321204 The kitchen hot water gets low on pressure and flow once in awhile. Took off the supply hose and there was a big piece of rust blocking the opening. I used a small screw driver to break it apart, flushed it out and now it's fine. Happens every once in awhile but what do you expect from a 100+ year old house. Report
September 16, 20233 yr Author Popular Post comment_321205 7 minutes ago, Harry Brink said: what do you expect from a 100+ year old house. much more than that Harry! Sounds like your home is doing well for its age. Report
