Popular Post steven newman Posted July 12, 2023 Popular Post Report Posted July 12, 2023 Had a bunch of Ash scraps...too thick too be used as is....decided to thin them down a bit....and try out the brand new tablesaw blade.. Old blade was starting to burn stuff...New blade had to be installed from UNDER the top of the saw...BTW.. Wanted to square the ends of some of the boards, and see what the cuts looked like.. Yes it is very sharp.. Cut is a tad on the rough side...then set up to do some resaw work... Zero Clearance Overlay...cut will leave 1/2" of "good" wood... Almost deep enough...so, to remove that last bit.. Disston D8 , 28", 5-1/2 ppi RIP saw.... Doesn't have quite as wide of a kerf, as the tablesaw does.. Once I got the middle of each board.. I was left with.. 5 pieces, 4" wide, by 1/2" thick..and five at 1/4" thick....same set up for the rest of the "scraps" These only needed 2 passes through the tablesaw...and.. These 3 only needed a single pass each.. Tablesaw was busy, today.. And the hand saw was too... Half of it's sawdust stayed up on the bench, the other half? Made a nice little pile on the floor below.... Will let the pieces sit a spell, while I decide on what to make with them....maybe another boring little box? Stay tuned.. Cal, Headhunter, Grandpadave52 and 6 others 9 Quote
Popular Post lew Posted July 13, 2023 Popular Post Report Posted July 13, 2023 Lookin' interesting! KevTN, Larry Buskirk, steven newman and 3 others 5 1 Quote
Popular Post Cal Posted July 13, 2023 Popular Post Report Posted July 13, 2023 13 hours ago, steven newman said: maybe another boring little box? Another you say? Haven't seen one yet! lew, KevTN, steven newman and 3 others 1 3 2 Quote
Gene Howe Posted July 15, 2023 Report Posted July 15, 2023 Not a boring one, anyway. That's for sure. lew, steven newman, Cal and 1 other 3 1 Quote
