June 12, 20233 yr Popular Post comment_315876 So the next thing on the to-do list for the wife is a new bed. This one has a number of requirements. It needs to be simple, sturdy, modern, with clean lines, has to be tall enough to sweep and mop under, with a big headboard and no footboard. If necessary, it should be able to be disassembled and moved. After a ridiculous number of designs I finally have one that has been approved and construction has begun. The splines at the end of the rails were the impetus for my recent bandsaw maintenance and upgrades. Report
June 12, 20233 yr Author comment_315879 Thanks, I am trying to talk the wife into further walnut accents on the headboard but so far she is not convinced. Report
June 12, 20233 yr comment_315880 Needs drawers underneath for storage. And then you can skip dusting. Edited June 12, 20233 yr by DAB Report
June 12, 20233 yr comment_315933 Love the corner castle joint! Smart idea to reinforce the rails there. Love the hand screw clamp detail as well. I suggest rotating it 45 degrees in plan view to reduce the chance of tripping on it. A notch in both jaws will help it clamp to the post at 45 degrees. 4D Report
June 14, 20233 yr Author comment_316007 Made a little progress tonight. One of the side rails is done and the other is in the clamps. Report
June 17, 20233 yr Author comment_316248 Progress has been made today. Still trying to figure out how I want to do the headboard but everything else is coming together nicely Report
June 18, 20233 yr Author comment_316251 Slats roughed in. Made decent progress today and I think I have the headboard figured out. Guess we will find out tomorrow Report
June 20, 20233 yr comment_316345 A suggestion: * Put a leg in the middle of the center rail. It's common with king and queen beds Report
June 20, 20233 yr Author comment_316347 there will be one, it is getting glued up at the moment Report
June 20, 20233 yr comment_316379 For a center leg, consider that human upper torsos are where most of our mass is. So rather than centered on the center rail put it 2/5 of the length from the headboard or there abouts. Might not make much obvious difference as hopefully the design is plenty strong, but the former structures class TA I played in college can't help but question common assumptions most make when there is a still time to encourage a slight structural improvement change. As for the headboard, are you planning adding any detail to it or a curved or stepped top edge? 4D Report
June 20, 20233 yr Author comment_316401 Went with a slightly stepped top edge with a slight angle that matches that of the legs then rounded and smoothed it out. Report
