May 7, 20233 yr comment_313815 3 hours ago, Lissa Hall said: Nothing for joint stuff I don't think. Drill press, big sander , table saw, scroll saw. Lathe, miter, pretty much covers it I think 🤔 You could frame a french door that size with pocket screws. If you check Amazon, there are pretty inexpensive PS systems. If you want visibility through the door, I suggest safety glass. Make the door, then measure the glass openings and go to a specialist shop. As an alt: ordinary glass, covered with clear adhesive shelf liner: tough stuff, won't shatter, darn near unbreakable. For that size door, I think 1x2 framing would work. https://www.amazon.com/gp/product/B092S8HBMS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B078GLWTZR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Report
May 7, 20233 yr comment_313817 3 hours ago, Lissa Hall said: Nothing for joint stuff I don't think. Drill press, big sander , table saw, scroll saw. Lathe, miter, pretty much covers it I think 🤔 With a table saw, you could make the door frame corners bridle joints and make dados around the inside of the frame for the lauan plywood Report
May 7, 20233 yr Author comment_313824 19 hours ago, Headhunter said: A bit off the wall and waaaay outside the box. How about a French door made of simple frames with tapestry fabric hung/stretched over them? Can get the look of both while minimizing the downsides of either. Well, you are asking for options. And I'm known around here for taking that road less travelled... That is a cool idea Report
May 7, 20233 yr comment_313825 As I look at the pics and think about the project I would go a much simpler route. First, the 31" width would not accommodate a traditional style double door with each door containing two columns of glass or panels. Two doors with one column each would work. But, you could take a bifold door set, remove the center hinges and hinge those doors from the outside edges. Bingo, solid french doors. Light, cheap, the 31" width is fairly standard so you have a lot of different styles to choose from. Dress them up any which way you choose. I did this exact project after years of fighting the bifold door on our pantry. And, pretty much the only tool you need is a screwdriver. Edited May 7, 20233 yr by Cal Report
