July 12, 20224 yr comment_294465 That job makes me smile! First I thought you had used alternating angled slats. Then I thought you glued square lengths together and turned it hollow. But now I'm not sure of anything! It is a mystery. Report
July 12, 20224 yr Author Popular Post comment_294468 1 hour ago, Woodman said: That job makes me smile! First I thought you had used alternating angled slats. Then I thought you glued square lengths together and turned it hollow. But now I'm not sure of anything! It is a mystery. I had some 1.5” square pieces of walnut and cherry left from a cutting board. I glued them together, turned it round and hollowed it out. Report
July 12, 20224 yr comment_294471 Like Lew said, everything looks centered and even. I like it. Did you leave the center piece long and chuck it up to center it? Report
July 12, 20224 yr Author Popular Post comment_294472 7 minutes ago, HandyDan said: Like Lew said, everything looks centered and even. I like it. Did you leave the center piece long and chuck it up to center it? No. Thanks for the idea, I never thought of that. I found center on both ends and turned it round with a spur drive and live center. Then I cut a tenon on both ends. Report
