MWTCA February 2021 'What's It' Project (m-10)
For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project"
Additional What's It Rules
  • Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source.
  • An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc...
Ok ladies and gentlemen, we now have our "What's it" live and ready!
    Project Details
    The information provided hereon is all the information that is provided, no further information on this item will be added.
    Item is around 5" long.
    that's missing a part.
    There's a  winding bobbin that needs to be on the right hand spindle  in the lower image.
    That bobbin  is where the flux capacitor  wire is  wound and spools off into the hollow of the capacitor  flux inducing well on the left.  the little round ripped  bits are adjustable to give the energy  of the Zen  of the tradesman  operating it   a conduit to flow into the nascent flux capacitor .  Onc the  dual bombardment of Chi energy  passes from the tradesman to the capacitor   you can use it to make  your  time traveling delorian.
    Cutter for copper pipe??
    Looks more like an Igniter for a torch....Squeese the flat disc into that slot, when you release it, friction sparks shower the inside of the igniter tube.   The 2 arms are more for "stand-offs" to keep your hand from getting burned...
    Edited by steven newman
    Except, brass don't spark?
     Looks kind of like a cad welder. Some sort of sleeve on the bobbin, scratches on the bobbin, and wrap the wire around the sleeve. Secure the wire ends around the rods with the ball ends to hold tension. Maybe then an outer jacket over the wire spool. Adjust the screw out to let the bobbin move against the collar and into the cup, burn marks on the collar & slag on the bobbin base, to hold everything in place. Load the charge in the cup and any welding action I believe is happening at the base of the bobbin.
     As I remember old tube TV's had some sort of weird copper wound coil.
    It "sparkles" when polished.
    When the Friction Coating is all worn off....leaves the Brass surfaces behind.....
    • 1 month later...
    Winner
    @Cliff has been selected as this months MWTCA Membership recipient.
    Since a verifiable answer was never arrived at for this item, we went to "close eyes and point at the computer selection" :D.
    Award
    Cliff, for your participation you have won a 2021 Calendar Year membership into the MWTCA.
    Please Private Message me your contact info, shipping address, spouse or significant others name (if applicable).
    Thank you all for your participation!
    Links
    Gristmill Magazine Sample
    the gristmill
    Congratulations Cliff :TwoThumbsUp:
    Congrats Cliff.
    Enjoy Cliff.
    Congrats Cliff.
    • 10 months later...
    You forgot to add that the bobbin gets attached with a self sealing stem bolt....
