John Morris Posted November 28, 2020 Report Posted November 28, 2020 1 hour ago, Cal said: Those are great boxes, for sure. What would have been the handle to box attachment method used by the Shakers? I don't know for sure Cal, but I'm thinking a clinched nail. lew, FlGatorwood, Larry Buskirk and 1 other 4 Quote
Popular Post John Morris Posted November 28, 2020 Popular Post Report Posted November 28, 2020 Or, in John Wilson's manual he uses a rivet. John is pretty accurate with his carriers and boxes. See attached .pdf J Wilson Shaker Boxes.pdf p_toad, Larry Buskirk, lew and 4 others 5 2 Quote
Popular Post kmealy Posted November 28, 2020 Popular Post Report Posted November 28, 2020 (edited) I've made a Shaker sewing box that is basically an oval box with a swiveling handle and another box with a non-swiveling one. The non-swiveling one uses some of John's copper nails that are a bit longer than the ones you use to assemble just the box. They are peened over on the inside. I think I'm going to put some of those berry boxes on my to-do list. How is the bottom attached? Edited November 28, 2020 by kmealy Gunny, John Morris, Artie and 4 others 7 Quote
kmealy Posted November 28, 2020 Report Posted November 28, 2020 !! https://www.etsy.com/listing/779678377/shaker-style-berry-box?gpla=1&gao=1&&utm_source=google&utm_medium=cpc&utm_campaign=shopping_us_a-home_and_living-home_decor-baskets_and_bowls&utm_custom1=_k_Cj0KCQiAh4j-BRCsARIsAGeV12BPBTIM9pVTf1EzabI-i-PVk0hxwZpOFduy7ZrViLLxfH5MFPTdD0oaArplEALw_wcB_k_&utm_content=go_2063077667_76452869215_367965824541_pla-302796601382_c__779678377_12768591&utm_custom2=2063077667&gclid=Cj0KCQiAh4j-BRCsARIsAGeV12BPBTIM9pVTf1EzabI-i-PVk0hxwZpOFduy7ZrViLLxfH5MFPTdD0oaArplEALw_wcB FlGatorwood, Cal and lew 3 Quote
Popular Post Danl Posted November 29, 2020 Author Popular Post Report Posted November 29, 2020 42 minutes ago, kmealy said: . I think I'm going to put some of those berry boxes on my to-do list. How is the bottom attached? 42 minutes ago, kmealy said: The sides are glued as depicted. After the glue dries, cut the 1/4" matl to size. Run a thin glue line around the top of the sides on the bottom side, all the way around. Clamp the bottom to the sides using painters tape. Danl Larry Buskirk, kmealy, Cal and 7 others 10 Quote
kmealy Posted November 30, 2020 Report Posted November 30, 2020 I can't read the dimensions from the FWW page on it, what are the dimensions of the side and end pieces? FlGatorwood, Cal, lew and 1 other 4 Quote
Popular Post Danl Posted December 1, 2020 Author Popular Post Report Posted December 1, 2020 15 hours ago, kmealy said: I can't read the dimensions from the FWW page on it, what are the dimensions of the side and end pieces? Length: 7-1/2" Wide: 5-1/2" Height: 3-3/8" Handle width: 1/2" kmealy, Larry Buskirk, FlGatorwood and 5 others 7 1 Quote
Popular Post kmealy Posted December 19, 2020 Popular Post Report Posted December 19, 2020 Just out of curiosity, how did you find working the 1/8" thick material? Other than Shaker oval boxes, I am not sure I've done much in that thinness. FlGatorwood, lew, John Morris and 2 others 5 Quote
Popular Post Danl Posted December 19, 2020 Author Popular Post Report Posted December 19, 2020 6 hours ago, kmealy said: Just out of curiosity, how did you find working the 1/8" thick material? Other than Shaker oval boxes, I am not sure I've done much in that thinness. I had to be a little more creative for glue clamp-up and the box joint index pin on the jig showed much wear after set-up and making only 5 boxes. My index pin was made from cherry wood. I may consider using a brass set-up bar next time if I had many to make. Danl Gunny, p_toad, DuckSoup and 2 others 5 Quote
Grandpadave52 Posted December 7, 2023 Report Posted December 7, 2023 Excellent Dan. I missed this post during my AWOL period. Thanks for the link refresher. Cal 1 Quote
