August 11, 20206 yr comment_238751 5 hours ago, AndrewB said: I'm assuming the plastics along with some sand paper correct? Sand paper first and then polish. Report
August 11, 20206 yr comment_238770 22 hours ago, FlGatorwood said: Isn't there a hard core to a bowling ball? I don't know how that would work out. I need to research that. Carl Jacobson on YouTube has done some and they didn’t have a hard core. Report
August 11, 20206 yr comment_238772 Also I bought a cheap paint pot to use for a pressure pot. You can make one pretty cheap like that. Report
August 11, 20206 yr comment_238775 On 8/10/2020 at 5:33 PM, RustyFN said: Going to be hard to get rid of the bubbles. Try to get some cheap bowling balls. They are resin and make great bowls. Rusty, if you have turned bowling balls, I'd love to see the finished product Report
August 12, 20206 yr comment_238793 Here you go Ron. I saw that Lew saw this one over a year ago. Report
August 12, 20206 yr comment_238794 11 hours ago, HandyDan said: I use Mequiar's Plastx from the auto parts store. Works very well and I've used it on the brass shells too. This is some great stuff for headlights and other plastics. Report
August 12, 20206 yr comment_238797 I have turned many small pieces of Acrylic and it was always a mess in my lathe area and even in my chuck. I can only imagine how bad his lathe and area was after turning that much plastic. Report
August 12, 20206 yr comment_238854 I noticed he used a vaccum . Wonder how that is to empty and does it clog up the pipes? Report
August 12, 20206 yr Author comment_238855 For now I think I may be holding off on a pressure pot for another month or two I'll probably buy a few acrylic blanks to get used to them to see if I even do like it and then if I enjoy the acrylics I'll dive heavy into resin casting. Report
August 12, 20206 yr comment_238868 38 minutes ago, AndrewB said: For now I think I may be holding off on a pressure pot for another month or two I'll probably buy a few acrylic blanks to get used to them to see if I even do like it and then if I enjoy the acrylics I'll dive heavy into resin casting. You might want to look at Liquid Diamonds. Friend who is into casting said it works without all that pressure and vacum an looks as good or better Report
August 12, 20206 yr Author comment_238869 Liquid Diamonds Huh I'm going to have to look that up on youtube later. That might be worth a shot. Report
August 12, 20206 yr comment_238870 They have a coupon on this site for 10% if you wait for it. https://www.theepoxyresinstore.com/products/crystal-clear-epoxy-resin-for-decorative-casting-and-crafting-liquid-diamonds Company support sounds good with a guarantee. Report
August 12, 20206 yr comment_238871 Check out the question section on the Liquid Diamonds Amazon site. The seller recommends a pressure pot. Report
August 12, 20206 yr comment_238872 Here is another site with directions and I did not see anything on pressure pot , but did not read word for word. I think the Amazon was a CYOA. https://www.artworksresin.ca/liquid-diamonds-directions Report
August 12, 20206 yr Author comment_238873 I found this video here but the person did NOT use a pressure pot. Report
August 12, 20206 yr comment_238880 3 hours ago, Gerald said: I noticed he used a vaccum . Wonder how that is to empty and does it clog up the pipes? I questioned him about that and he said he removed the screen from in front of the impeller. He didn't say about emptying it. Report
August 19, 20206 yr Author comment_239679 I just mixed added color and pored the FIRST Resin this is with the Liquid Diamonds. So it was a 2 to 1 ratio and I'm hoping I did this correctly. How ever we shall see if it was done correctly in about 24 hours or so. Sheesh that stuff is MESSY. Good thing I had rubber gloves. I stuck it into a cardboard box JUST in case it decided it wanted to leak on me. How ever I don't think I'll have too much of an issue with it. Its just big enough to get two pen barrel blanks out of as well. I used a darker color mix as well. Report
