steamshovel Posted March 1, 2020 Report Posted March 1, 2020 Does anyone have the formula for a bees wax finish? I had it but it got lost. Preston Cal 1 Quote
lew Posted March 1, 2020 Report Posted March 1, 2020 I mix it about 4 to 1 oil to wax. I think you are supposed to do it by weight but mostly I just guess. Depends on if I want it buttery or firm steamshovel and Cal 2 Quote
Gerald Posted March 2, 2020 Report Posted March 2, 2020 The only formula I have is rough based on about 8oz oil and a egg sized piece of beeswax steamshovel and Cal 2 Quote
Fred W. Hargis Jr Posted March 2, 2020 Report Posted March 2, 2020 What they said^^^^^, there's no "perfect" mix. Adjust as needed. steamshovel and Cal 2 Quote
Cal Posted March 2, 2020 Report Posted March 2, 2020 (edited) What type of oil do you use? Would it change depending upon the project? Edited March 2, 2020 by Cal steamshovel 1 Quote
lew Posted March 2, 2020 Report Posted March 2, 2020 40 minutes ago, Cal said: What type of oil do you use? Would it change depending upon the project? Mineral oil from the grocery store. Located in the first aid isle. Usually stocked with the laxatives. Cal and steamshovel 1 1 Quote
steamshovel Posted March 2, 2020 Author Report Posted March 2, 2020 I wrote down the formula and lost it. There was 4 items bees wax, boiled linseed oil. varnish or tung oil, and ? I used it on the sewing machine cabinet I made for my wife 35 years ago. It has worn good.I had a tread on the cabinet here. Preston Cal 1 Quote
Fred W. Hargis Jr Posted March 2, 2020 Report Posted March 2, 2020 Others will chime in, but the only thing I know of that's close to what you describe is Beeswax, MS (or turpentine, to dissolve it) and then BLO. But I've only used that on workbench tops....and it's great for that. steamshovel and Cal 2 Quote
lew Posted March 2, 2020 Report Posted March 2, 2020 50 minutes ago, Fred W. Hargis Jr said: I've only used that on workbench tops....and it's great for that. The one I suggested is great for food safe surfaces steamshovel and Cal 2 Quote
Fred W. Hargis Jr Posted March 2, 2020 Report Posted March 2, 2020 (edited) Absolutely! Without the solvents it's food safe. Do you melt the bees wax in a double boiler, then mix it with the mineral oil? Edit in: I had to go back and check Flexner's book. I realize that all finishes are non-toxic (once fully cured), but I wasn't sure this meant food-safe. According to Bob, "all finishes are safe to eat off of or chew on once the finish has fully cured". I had wondered about the metallic driers in BLO and varnishes, but they are not a problem. Edited March 2, 2020 by Fred W. Hargis Jr Cal and steamshovel 2 Quote
Gerald Posted March 3, 2020 Report Posted March 3, 2020 All of this depends on what you put it on. If for a cutting board or other food contact I use mineral oil and bees wax. If not a food surface I use turpentine or mineral spirits , BLO and beeswax. Note turpentine has a nice strong smell. Either finish will need to be replenished . Cal and steamshovel 2 Quote
kmealy Posted March 4, 2020 Report Posted March 4, 2020 There seem to be two threads: - Bees' Wax and mineral oil for things like cutting boards or "charcuterie" (a nod to @Fred W. Hargis Jr - Bees' Wax and boiled linseed oil, usually with a thinner like turpentine and/or mineral spirits, as a polish or finish by itself https://www.popularwoodworking.com/woodworking-blogs/make-linseed-oil-wax-finish/ What you do NOT want is to add vinegar with the linseed oil. Article written by Donald C. Williams Senior Furniture Conservator, Conservation Analytical Laboratory at the Smithsonian Institution Drying oils, such as linseed, tung, or walnut oil, are a different matter altogether. These materials solidify, or "dry" through a process of chemical reaction with the air called oxidation. The drying process polymerizes the oil, making it increasingly intractable with time and more difficult to remove with cleaners or solvents. This is fine if oil is employed as the finish, but not good if it is used as a polish. By itself, having a polish which is difficult to remove would be irritating but not insurmountable. Unfortunately, this is not the whole story. As drying oils age, they tend to become yellow or brown. Also, drying oils are chromogenic (they become colored) in the presence of acids. In this instance the oil adopts the dark, muddy brown/black opaque appearance so prevalent in antique furniture. Traditionally, cleaning/polishing concoctions were comprised of linseed oil, turpentine, beeswax, and vinegar (acetic acid). This cleaning/polishing method, used widely even in the museum field until recently, was and is a disaster waiting to happen. The results of this approach are readily apparent to even the casual observer; a thick incrustation of chocolate colored goo which is neither hard enough to be durable nor soft enough to wipe off easily. Thus, due to the polymerization of the oil as it dries and the reaction of the oil with acetic acid, the furniture is left with an unsightly coating which is very difficult to remove without damaging the surface of the object. Cal, Fred W. Hargis Jr, steamshovel and 3 others 3 1 1 1 Quote
Popular Post Gunny Posted March 4, 2020 Popular Post Report Posted March 4, 2020 33 minutes ago, kmealy said: Thus, due to the polymerization of the oil as it dries and the reaction of the oil with acetic acid, the furniture is left with an unsightly coating which is very difficult to remove without damaging the surface of the object. So this won't cut it?? Asking for a friend.... Fred W. Hargis Jr, p_toad, Gerald and 4 others 1 6 Quote
Popular Post Gerald Posted March 4, 2020 Popular Post Report Posted March 4, 2020 1 hour ago, Woodbutcherbynight said: So this won't cut it?? Asking for a friend.... Are we going to have ro raid your shop and confiscate the contraband? Gunny, steamshovel, Fred W. Hargis Jr and 5 others 2 6 Quote
Cal Posted March 5, 2020 Report Posted March 5, 2020 19 hours ago, kmealy said: This cleaning/polishing method, used widely even in the museum field until recently, was and is a disaster waiting to happen. I am guessing that this reaction is not very quick then? Good info Keith, thanks. steamshovel 1 Quote
Popular Post kmealy Posted March 5, 2020 Popular Post Report Posted March 5, 2020 20 hours ago, Woodbutcherbynight said: So this won't cut it?? Asking for a friend.... Brought to you by p_toad, Gene Howe, Fred W. Hargis Jr and 3 others 1 5 Quote
Michael Thuman Posted March 6, 2020 Report Posted March 6, 2020 On 3/4/2020 at 12:49 PM, Woodbutcherbynight said: So this won't cut it?? Asking for a friend.... Pledge has silacone in it whch ruins the wood. Do not use this product. Gunny, p_toad, steamshovel and 1 other 3 1 Quote
Gunny Posted March 6, 2020 Report Posted March 6, 2020 (edited) 1 hour ago, Michael Thuman said: Pledge has silacone in it whch ruins the wood. Do not use this product. Thanks. I was messing with @kmealy. He posted about that issue awhile back. Myself I have never used it. Edited March 6, 2020 by Woodbutcherbynight p_toad, steamshovel and Cal 3 Quote
