November 1, 20197 yr comment_207206 "What's It" Basic Rules Reminder For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project" Only Patriot Woodworker Members are eligible to participate and receive the award. The MWTCA only accepts a verified source to support your answer, so one should be submitted with your answer, such as a patent, catalog entry, tool book reference, or a respectable website on the subject. Do not let these requirements prevent you from having fun and submitting educated answers on the subject without verification, we can worry about references later. All answers are welcome, as well as healthy debates regarding "What's It". If a verified and referenced answer is not arrived at by the end of each month's "What's It" project, a random draw will be performed for a "One Year MWTCA Club Membership". Only Patriot Woodworker's who participate in this "What's It" topic will be included in the random draw. Additional What's It Rules Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source. An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc... Ok ladies and gentlemen, we now have our "What's it" live and ready! The image(s) below is a MWTCA "What's It" image for you to research, and tell us all here in this topic post, just what the heck is it! Project Details The information provided hereon is all the information that is provided, no further information on this item will be added. Report
November 1, 20197 yr comment_207243 Crimping pliers, for doing Standing Seam metal roofing.... Probably made by Krueter... Report
November 1, 20197 yr Author comment_207250 5 hours ago, steven newman said: Crimping pliers, for doing Standing Seam metal roofing.... Probably made by Krueter... It's the wrong configuration Steve. That's not how the seam is configured or looks for Standing Seam roofing. And, the typical crimps for metal roofing are quite large with long handles, and the crimp itself is long. There is no way in heck you could get the leverage to bend that heavy gauged metal for roofing with those small pliers handles. Report
November 1, 20197 yr Author comment_207263 3 minutes ago, Larry Buskirk said: Split ring terminal crimping pliers. You gotta a similar pic or reference Larry? Sounds like you seen these before? Report
November 1, 20197 yr comment_207264 1 minute ago, John Morris said: You gotta a similar pic or reference Larry? Sounds like you seen these before? John, Yes I've seen these before. For crimping terminals onto larger gauge wires. I'll have to see if I can find a photo IIRC they're made by Klein. Report
November 1, 20197 yr comment_207266 Name I was looking for was Kraueter Tool Co. as it looked like their style of pliers. Report
November 2, 20197 yr comment_207313 sounds like Larry is onto something. I was thinking pliers to crimp the connector making a loop end in cable.Will be interesting to see what Larry finds. Report
November 2, 20197 yr comment_207376 10 hours ago, Gerald said: Will be interesting to see what Larry finds. Dang...Larry struck out finding a photo. .. I'm not positive on the manufacturer of these "pliers/crimpers". I saw the electricians using these when I worked in the skilled trades at Chrysler. 10 hours ago, Gerald said: I was thinking pliers to crimp the connector making a loop end in cable. They were also capable of doing just that with smaller size cable. There were a few different shaped sets of jaws for them. Hey!!!... @Artie, Do you know the brand name of these "pliers/crimpers"? Report
November 8, 20197 yr comment_208061 Hey Artie is making dust in the shop now, haven't you heard? Report
November 20, 20196 yr comment_209518 I've been thinking along the same line as Larry. Crimpers for CTAP connectors but can't reproduce a picture of this tool. I think today these are used. Edited November 20, 20196 yr by HandyDan Report
November 25, 20196 yr comment_210075 I do not think it is for crimping electrical connectors. It is nothing like any of the old crimpers that I have seen. This would be very unweildy to use as you would have to squeeze the handles together while holding the two pliers flat. The sharp edges on the pins would tend to cut or split the connector, normally the part that compresses the connector is rounded to prevent that. Roly Report
November 25, 20196 yr comment_210098 1 hour ago, Roly said: This would be very unweildy to use as you would have to squeeze the handles together while holding the two pliers flat. Once you start squeezing the handles it would lock itself into place. Report
November 25, 20196 yr comment_210153 I think you are right about locking itself when squeezed. But I am not buying it is for electrical crimp type connectors. Roly Report
November 27, 20196 yr comment_210400 With the screws the pointed ends are adjustable. But I agree not for electrical unless they are made to bite into solid core wire. Once closed they lock on to what they are being closed upon. So I think it is use as a torque or rotational device. Edited November 27, 20196 yr by Michael Thuman Report
December 1, 20196 yr Author comment_210877 Any final thoughts on this item before we go to random award of MWTCA membership? Seems there really isn't any reliable sourcing of this item yet? Report
December 1, 20196 yr comment_210908 Okay one last WAG and no evidence of course.. Used to open up wire winch cable when splicing pieces together. Report
