October 12, 20197 yr comment_204914 1 minute ago, BillyJack said: Don't feel bad mine was over 100k and still growing... This is the third time. Report
October 12, 20197 yr comment_204933 I have used Timberwolf and the Highland turners blades and all were good but since I am kinda rough on blades getting kinks I changed to a local supplier. I get a 3 tpi 1/2 inch blade from a place called Fersco who also does commercial blades and they cost less than 10 but last me 3 to six months . Most of the cutting I do is blanks for turning and a lot of that is green wood. Since I got the Carter berings setup it is even better. Even with a kink in the current blade does well. By the way I usually sharpen my blades 1 or 2 times before change. Report
October 12, 20197 yr Author comment_204940 6 hours ago, John Morris said: Good morning Pat, what are you cutting, or going to cut, what would be the thickest lumber approx and do you cut mainly hardwoods or soft? Most of the work on the bandsaw consists of 1/2-3/4" hardwoods, with some occasional softwoods thrown in. Report
October 12, 20197 yr comment_204941 2 hours ago, Larry Buskirk said: This is the third time. Remember 1OOk to take kidney who knows what it will cost to put a new one in. I'm hoping the insurance covers it.. Report
October 12, 20197 yr comment_204942 I'd still be interested in a worst to best and best values summary. Report
October 12, 20197 yr comment_204949 1 hour ago, Gerald said: I have used Timberwolf and the Highland turners blades and all were good but since I am kinda rough on blades getting kinks I changed to a local supplier. I get a 3 tpi 1/2 inch blade from a place called Fersco who also does commercial blades and they cost less than 10 but last me 3 to six months . Most of the cutting I do is blanks for turning and a lot of that is green wood. Since I got the Carter berings setup it is even better. Even with a kink in the current blade does well. By the way I usually sharpen my blades 1 or 2 times before change. Do they make custom lengths? Do they ship? Web site? I'd like to order some. Report
October 12, 20197 yr comment_204961 Suffolk Machinery sells Timberwolf blades and can make any size needed. Edited October 12, 20197 yr by Fred W. Hargis Jr Report
October 13, 20197 yr comment_204985 4 hours ago, Gene Howe said: Do they make custom lengths? Do they ship? Web site? I'd like to order some. This is the catalog but I cannot tell if they ship other than commercial. https://www.ferscosaws.com/sites/default/files/2018_catalog.pdf Report
October 13, 20197 yr comment_204987 I am with the Timberwolf / Suffolk Machinery crowd. Have used for last 7 years and still cuts sweet. I went with a 3/16 blade for short radius cuts using a circle jig, and a 3/4 blade for re-sawing. Report
October 13, 20197 yr Author comment_205086 Guys, didn't really learn too much about my situation but allot about where to get custom blades and everybody's medical mishaps. ;-) Save two. Hope everybody is now doing well except for those major bills. Mine were $78k for my heart surgeon. Report
October 13, 20197 yr comment_205102 Pat, the Olsen blades are a good quality blade. I've been using them for a few years and happy with them. The smaller you go the sharper the radius you will get. 1/8" blades are used for scrolling along with a Carter guide bearing set up. The guides make a big difference for the thinner blades. Report
October 13, 20197 yr comment_205103 1 minute ago, HandyDan said: The smaller you go the sharper the radius you will get. This is why I have the 3/16 blade, can make a very sharp radius with my circle cutting jig if needed. Also for those exotic radius curve cuts it helps to not bind the blade. Report
October 13, 20197 yr comment_205106 Pat, Sorry about the sideways track. Not sure what size/brand of bandsaw you're using but the general rule is that wider blades get used for straight cuts. As to the TPI the more aggressive (less TPI) blades don't make as smooth of a cut and get used more for re-saw work. Edited October 14, 20197 yr by Larry Buskirk Report
