Cal Posted July 6, 2019 Report Posted July 6, 2019 That is excellent, all around Pauley. FlGatorwood 1 Quote
Smallpatch Posted July 6, 2019 Report Posted July 6, 2019 I love to see carving and the things a person can do to make it their personal expressions... I don't know if you use the knives or electric grinders but if you don't know about Wood Carvers Supply, Inc then check them out. I am lazy so I use grinders only and have found their bits are top of the line and last a very long time...I keep three electric Dremels hanging all the time with different bits for the stopping and changing bits kinda stops my thinking about my next step..and by the way don't even consider Dremel bits for they don't last long enough...Check some of my pictures and see if what the grinder results can help you also... Smallpatch Cal, Artie, p_toad and 1 other 4 Quote
Pauley Posted July 7, 2019 Author Report Posted July 7, 2019 On 7/6/2019 at 7:09 AM, Cal said: That is excellent, all around Pauley. Thank you. I wanted to try and do something I’d never seen done before. Not saying it hasn’t been done, just that I have never seen it. Quote
Pauley Posted July 7, 2019 Author Report Posted July 7, 2019 On 7/6/2019 at 11:09 AM, Smallpatch said: I love to see carving and the things a person can do to make it their personal expressions... I don't know if you use the knives or electric grinders but if you don't know about Wood Carvers Supply, Inc then check them out. I am lazy so I use grinders only and have found their bits are top of the line and last a very long time...I keep three electric Dremels hanging all the time with different bits for the stopping and changing bits kinda stops my thinking about my next step..and by the way don't even consider Dremel bits for they don't last long enough...Check some of my pictures and see if what the grinder results can help you also... Smallpatch Wow! That’s good to know. I did that with a Wen grinder (Drexel knockoff...I’ve always had bad luck with a dreamer for some reason). I check them out for sure. Thank you. Quote
