January 23, 20197 yr comment_175497 Please see the below where I have unstainable squigles in the raised panel. Probably glue line or squeeze out. Do I dare to strip and sand out risking cutting thru the veneer? Maybe a brown and black sharpe? Need your help! Report
January 23, 20197 yr Author comment_175604 I really need a timely response. I am stalled and cannot move forward. Report
January 23, 20197 yr comment_175606 That is the veneer stitching showing, I have no solution. Nice color. Herb Edited January 23, 20197 yr by Dadio Report
January 23, 20197 yr Author comment_175609 1 hour ago, Dadio said: That is the veneer stitching showing, I have no solution. Nice color. Herb So Veneer stiching cannot be sanded out. If I cannot color it then I have to live with it? Report
January 23, 20197 yr comment_175614 Does any one but you see it, or comment on it? I have no solution, but if it were me I would experiment on an obscure place with those stain felt pens to see if there was a way to break up the pattern so it would be less noticeable. I have seen the painters draw in grain on wood such that it looked real. It will be a time consuming job though. Are these new doors or are you refinishing old doors? Herb Edited January 23, 20197 yr by Dadio Report
January 23, 20197 yr comment_175617 Don't believe I ever seen a zigzag line like that before. Its sure not glue ease out. 50 years from now you won't even think about any more... Report
January 23, 20197 yr comment_175623 Call in my ignorance How do you do a raised panel with veneer? All I have done and seen are solid wood or plastic. If this is wood can sand , if not maybe make a matching strip (no squiggle) on both sides of the door to cover it Report
January 24, 20197 yr comment_175635 Michael, not being a smart arse, but I like it, I love inconsistencies in work, I'd keep it. Seriously. I would not try to fix it even if I wanted too. Report
January 24, 20197 yr comment_175647 2 hours ago, John Morris said: Seriously. I would not try to fix it even if I wanted too. I agree, adds character to it. Who would think a tree had stitching? It has a unique and very even appearance. Report
January 24, 20197 yr Author comment_175672 OK thanks for all your replies. I will leave it along and make it a feature to be enjoyed or ignored. Thanks all. Report
January 26, 20197 yr comment_175791 On 1/24/2019 at 5:09 AM, Michael Thuman said: OK thanks for all your replies. I will leave it along and make it a feature to be enjoyed or ignored. Thanks all. That's the spirit!!!!!!! Report
January 26, 20197 yr comment_175841 Since we cannot tell how noticeable it is, or which panel it is on; please let us know if anyone ever asks about it. Could the door be swapped with another in the house that would be in a less noticeable spot? Report
January 26, 20197 yr comment_175872 Was the veneering done with a vacuum press and heat ? Only way to veneer a raised panel that I know of. If so the issue is the stitching is a hot melt glue process and then heating it again with more glue probably made it bleed through the veneer. I would consider placing a coat of finish on then see if glazing will blend it in more if you want. Roly Report
