January 18, 20197 yr comment_174894 We have a house new to us and it has painted wood trim (pine) white that does not fit the character of the ranch house. I am replacing that trim with the following. Doors flutes, rosettes, and plinth blocks Windows flutes, rosettes, jamb, sill Baseboards , plain board 4 to 6" tall then quarter round on the floor and cove molding on the top. In your humble opinion should I invest in real wood mouldings (oak stained and dyed to highlight the grain) or MDF painted white. The investiment will be substantial and I need to know which this community would like to go for. IF natural more detail work to get everything tight and looking good. If mdf (cheaper than oak) and white trim can be flubbed with caulk. Report
January 19, 20197 yr comment_174990 I used oak baseboard (no QR) and she likes the appearance. I think it's pretty arbitrary, and it's pretty yours. Report
January 21, 20197 yr Author comment_175322 Well the hardwood floors had to gap the wall by 1/2" each side so the QR is used to hide any gaps and keep legs and stuff from marking up the baseboards. Report
January 22, 20197 yr comment_175407 A lot depends on the theme, if you have one. I work with a interior decorator from time to time and she keeps to a theme. If you had say a country style theme then paint would not really be in the mix. But she never uses the MDF for anything. Granted she is picky but her work speaks for itself once done. Report
January 22, 20197 yr comment_175454 23 hours ago, Michael Thuman said: Well the hardwood floors had to gap the wall by 1/2" each side so the QR is used to hide any gaps and keep legs and stuff from marking up the baseboards. Whoever (I wasn't there in '87) installed our drywall left about 3/4" gap under it. Flooring covers (wood and carpet) were installed to edge of DW, and that meant baseboard alone could cover gap. I've also seen really thick baseboard used that did the same thing. Some one was using 3/4" alder for bb. Beautiful, but maybe too much. Report
January 22, 20197 yr comment_175465 a lot of nice hardwood is painted over 2nd time around, Just Saying, Herb Report
January 22, 20197 yr comment_175467 11 minutes ago, Dadio said: a lot of nice hardwood is painted over 2nd time around, Just Saying, Herb criminal... ain't it... Report
January 23, 20197 yr Author comment_175499 here is a picture of the door which is what the trim will look like also. Those squiggles are a problem and I just put it on the finising forum for advise. Edited January 23, 20197 yr by Michael Thuman Update text Report
January 23, 20197 yr comment_175605 17 hours ago, Michael Thuman said: here is a picture of the door which is what the trim will look like also. Those squiggles are a problem and I just put it on the finising forum for advise. Micheal, that is where they stitched the veneer when they made the door panel. You can see the narrow piece of veneer between the wide grain if you look closely. I like the color,good match. Herb Edited January 23, 20197 yr by Dadio Report
