Smallpatch Posted December 7, 2018 Report Posted December 7, 2018 Need to make a few of these by you know when....I" thick maple is way too think for these small skinny letters..did some resawing to make sure when I cut out one of these letters I will be able to push it out one direction or the other.. These are a few of the resawed 12"x12" I needed for these logo's. Even though my maple has been in my shop for about 15 years and when I bought the large amount of the ruff lumber they said it had been milled some 10 years before the auction.. But any time I resaw 1" lumber I am parting some wood that has never been out in the air so I take no chances for warping to take place. I clamp it up so it will all stay straight until I start using it.. Now I'm waiting on some real small blades which has been ordered way too long and not gotten here yet...I hope they don't have to drive over to Germany to pick them up... They should have had them in stock anyway... The letters are only about 1/2" tall so I gotta hide the booze for the next few days. These shaky hands needs to calm down... I've cut out some of the bigger items and I might add when cutting things like this, once you start sawing, don't stop until you get back to the starting point cause if you do it will show up big time. I also have found over the years to get the best results I only go in one direction..that means I'm always turning the wood clockwise as I saw.... One good thing about using decient blades is when I finish scroll sawing I never have to give any attention to the flat areas the blade cut only the edges might need rounding a hair or not depending on the look a person is after. The blades make the flat areas smoother than what a person can make them with sand paper. If the blades are used too long a smell of burnt wood will give you a hint and burn marks will start to appear.. I've been using blades that are .013 wide and am waiting on some .011 wide. I've never cut out anything like this for the letters are out in the middle of no where so mistakes will show big time... DuckSoup, Harry Brink, Grandpadave52 and 1 other 4 Quote
Smallpatch Posted December 9, 2018 Author Report Posted December 9, 2018 This is about to eat my lunch!! Those very small blades came today and they are so thin I can't turn the wood as fast as I need to for the blade keeps going straight. Gotta think this project over. Grandpadave52, Dadio, Cal and 1 other 4 Quote
Cal Posted December 9, 2018 Report Posted December 9, 2018 Interesting that the small change in blade width made such a big difference in the operating characteristics. I am sure that you experimented with blade speed. I do not have anything else to suggest with these blades. Quote
Wichman3 Posted December 9, 2018 Report Posted December 9, 2018 I have two suggestions: 1. slow your feed rate, give that small blade time to cut and turn. 2. practice on scrap (of the same material). short sections with a 1" straight line, cut to the center and then spin the blade in place (slowly) cut back out the same line you cut in on. When you are comfortable with the straight lines, work on some "S" curves. An additional practice is to tilt the table and cut the straight line again, this will result in a cone waste piece, practice until the cone is even. Additionally, I have trained myself to be able to cut either direction, I prefer clockwise (just feels better somehow), but in the fretwork I do I have to be able to cut counterclockwise at times. Artie and Grandpadave52 2 Quote
Wichman3 Posted December 9, 2018 Report Posted December 9, 2018 This is a small box I used to make. 1 1/2" thick purpleheart with a sliding dovetail on the top and a heart shaped pin to hold the top in place. I had to use very small blades (#1) and cut slowly. Grandpadave52, Artie, Cal and 1 other 4 Quote
Grandpadave52 Posted December 9, 2018 Report Posted December 9, 2018 I'm just gonna' watch and maybe I can learn something here. First thing I would need is one of those big, lighted magnifying lenses. Next thing would be not to stick my tongue on the table till it warms up 50-60 degrees. Cal and Artie 2 Quote
Popular Post Smallpatch Posted December 11, 2018 Author Popular Post Report Posted December 11, 2018 Okay this is a little better but not something I want to put my name on. I went back to the larger blade...The small blade would keep going straight when I tried to spin the wood around. And I lost the center of the R. The 0's, the A's and the R's are just just laying in there for now.. DuckSoup, Grandpadave52, hawkeye10 and 2 others 5 Quote
Grandpadave52 Posted December 11, 2018 Report Posted December 11, 2018 8 minutes ago, Smallpatch said: but not something I want to put my name on. Well shucks...you can put my name on it then Patch. I'd be pretty proud of myself to have something turn out that nice. Cal and hawkeye10 2 Quote
Smallpatch Posted December 11, 2018 Author Report Posted December 11, 2018 Dave I'm glad you replied to that . I didn't finish that not putting my name on........ I meant to add YET. I still have some fine tuning to do before I am finished . And I will have to think about what it is I can do for me to accept it!!!! My problem is not wanting to admit age is having something to do with my quality of woodworking and I might add everything else also... Cal, Grandpadave52, Artie and 1 other 4 Quote
Smallpatch Posted December 11, 2018 Author Report Posted December 11, 2018 I've always used that thought when completely a project.... Now the next time I can make it better by doing this and that...... If someone likes this, just wait till they see the next one... Gene Howe, Artie, DuckSoup and 1 other 4 Quote
Gene Howe Posted December 11, 2018 Report Posted December 11, 2018 I agree with Dave. Looks purdy derned nice, too me. Cal, hawkeye10, Artie and 1 other 4 Quote
hawkeye10 Posted December 12, 2018 Report Posted December 12, 2018 I agree with, Gene and Dave it does look nice. You were talking about blades. Have you ever tried Pegas blades? The Modified Geometry blades are what I use and I like the #5 the best. The main thing I like is you feed your material straight into the blade instead of at an angle like other blades. Do what I did and order a dozen or two and see if you like them. That is the only way you will know. Look to the right on your screen to buy them by the dozen. If you buy some let me know what you think. https://www.dndsawbladesonline.com/page/79818204 Harry Brink, Cal and Gene Howe 2 1 Quote
