Popular Post Ron Altier Posted October 23, 2018 Popular Post Report Posted October 23, 2018 I saw an interesting way to glue a cracked board. The piece was cracked at the end with a crack about 8 inches long. The guy had opened it just enough to get a piece of dental floss thru. He put glue in and on the crack and ran the floss back and forth to spread the glue thru the crack. I will have to try this one, I think it can work. Cal, Harry Brink, Fred W. Hargis Jr and 3 others 6 Quote
Popular Post lew Posted October 23, 2018 Popular Post Report Posted October 23, 2018 I've used the shop vac trick. Apply the glue to the top of the board on the crack and put the shop vac hose on the other side of the board over the crack. The suction pulls the glue into the crack. Fred W. Hargis Jr, Cal, Grandpadave52 and 3 others 6 Quote
Popular Post PeteM Posted October 23, 2018 Popular Post Report Posted October 23, 2018 This is why I visit this site! Great ideas. If I put the vac in one ear and suck the dental floss through the other ear, will it improve my memory so I remember this tip? steamshovel, Larry Buskirk, lew and 6 others 1 7 1 Quote
Gene Howe Posted October 23, 2018 Report Posted October 23, 2018 I wouldn't try it, Pete. Dental floss is a removal device. Grandpadave52, Artie, Cal and 1 other 4 Quote
Popular Post Dadio Posted October 23, 2018 Popular Post Report Posted October 23, 2018 Well, finally a use for dental floss. Thanks for posting, I am going to try that, if I can find any dental floss. Herb Artie, Al B, Grandpadave52 and 2 others 5 Quote
Popular Post Cliff Posted October 23, 2018 Popular Post Report Posted October 23, 2018 (edited) Quote Hope he has unwaxed floss. I use an air gun to drive glue in. Edited October 23, 2018 by Cliff Gene Howe, Grandpadave52, Dadio and 2 others 4 1 Quote
lew Posted October 23, 2018 Report Posted October 23, 2018 8 minutes ago, Cliff said: I use an air gun to drive glue in. That always splatters it for me. Dadio, Cal and Grandpadave52 3 Quote
Grandpadave52 Posted October 24, 2018 Report Posted October 24, 2018 16 hours ago, lew said: That always splatters it for me. Cal, lew, Dadio and 1 other 4 Quote
Al B Posted October 24, 2018 Report Posted October 24, 2018 Do you have ghosts in your closets Dave? Grandpadave52 and Cal 2 Quote
Grandpadave52 Posted October 24, 2018 Report Posted October 24, 2018 5 minutes ago, It Was Al B said: Do you have ghosts in your closets Dave? No, just skeletons Cal 1 Quote
Smallpatch Posted October 24, 2018 Report Posted October 24, 2018 (edited) I have a rubber tipped blo gun and this works for me and sometimes there is no other side where I could use a vac. And if I don't want the extra glue on the surface I use these 12" long feeler gauges that go down to .0015 for the really thin cracks... Edited October 24, 2018 by Smallpatch Cal and Grandpadave52 2 Quote
Buckaroo Posted October 24, 2018 Report Posted October 24, 2018 Whittle toothpick down and packed it in, works fer me. Grandpadave52 and Cal 2 Quote
Grandpadave52 Posted October 24, 2018 Report Posted October 24, 2018 1 hour ago, Buckaroo said: Whittle toothpick down Now those I can make...usually need 3 or 4 good 8 foot 2x4's to make a batch, but I'm getting better at it. Cal and Stick486 2 Quote
Cliff Posted October 29, 2018 Report Posted October 29, 2018 On 10/23/2018 at 3:51 PM, lew said: That always splatters it for me. Can't have it on the surface. It's gotta be inside the crack then the air drives it deeper lew 1 Quote
steamshovel Posted October 29, 2018 Report Posted October 29, 2018 I use a 6" fire hose between my ears! Preston Grandpadave52 1 Quote
Kevin Beitz Posted October 13, 2019 Report Posted October 13, 2019 On 10/23/2018 at 1:53 PM, Gene Howe said: I wouldn't try it, Pete. Dental floss is a removal device. The dental floss remove the air and gives room for the glue... Quote
BillyJack Posted October 13, 2019 Report Posted October 13, 2019 I'll have to keep the floss trick in mind. Usually if i can spread it I can get a syringe in it. lew and Gunny 2 Quote
